Results 1 to 8 of 8
Thread: Strange Clunk Noise
    05 VZ
    Nov 2005
    Default Strange Clunk Noise
    hey have any vz owners had this or a similar problem. Lately when driving, if i go over a bump in the road i can hear and also feel (vibration) a noise under the car. i am not sure where it is coming from but it happens every time i turn into a driveway, and also if i am driving straight and turning the wheel clockwise and anticlockwise fast.
    any clues anyone? could this be ball joints or something loose underneath? suspension problem? any help is appreciated. cheers
    vy series 2 v8 berlina
    Dec 2006
    [QUOTE=fullaaa;765434]hey have any vz owners had this or a similar problem. Lately when driving, if i go over a bump in the road i can hear and also feel (vibration) a noise under the car. i am not sure where it is coming from but it happens every time i turn into a driveway, and also if i am driving straight and turning the wheel clockwise and anticlockwise fast.
    any clues anyone? could this be ball joints or something loose underneath? suspension problem? any help is appreciated. cheers[/QUOTE There is a brace on both sides of the car(front end)they are bolted from the chassis rail to the fire wall.Try tightening them up as they work loose over time and cause the problem you are describing.Cheers.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    tigerpm7's Avatar
    tigerpm7 is offline Gotta love the VZ
    VZ Commodore Executive MY06
    Mar 2008
    Arrow
    This is interesting and i'm glad someone has bought it up. I find exactly the same noise when turning into a driveway. Only when i'm not going in slowly. I thought it was the mudflap rubbing but after I read this post I took the mudflap off and tried again and the clunk is very prominent. Haven't got esp as asked. Hope someone can help.
    He who hesitates shall hesitate last.
    05 VZ
    Nov 2005
    its only an exec so it doesnt have esp as far as i know. Some people reckon it could be bushes or a link pin..? Anything in particular i should be looking out for as far as this brace goes or does it look prominent when i'm under the car? thanks
    VZ 2005 V6 175 Alloytec
    Mar 2006
    Newcastle NSW
    I think its thats false floor in the boot
    well it sounds like it
    cause mine does it too
    DRIVE IT LIKE YOU STOLE IT
    05 VZ
    Nov 2005
    false floor? i've checked the left compartment where the jack is and there is nothing else in the boot that could be rattling around. I'm sure its something mechanical becauase you can feel the 'thud' or 'clunk' under the floor it feels but there is something in the rear i think also. not sure if its the same noise but its doing my head in. cheers
    2005 VZ SV6 A5 & 1997 VS II A4
    Sep 2006
    SE Qld
    The front stabilizer bar on my SV6 moves sideways through the clamps/mounts over time, and the end section of the bar makes contact with the front radius rod sometimes. This produces a clunk that may be the same as you are getting. I'm not sure that the standard and FE2 suspensions are that much different from each other but it may pay you to have a look at yours. On the FE2, the bar and the radius rods are fairly close to each other which may be due to the lower ride height.
    Have a look down from the top just in front of the engine and see how far the bends in the stabilizer are from each of the two mounts. Also have a close look under the car to see if the ends of the stabilizer have been contacting the radius rods. Mine has left a mark where the bar and radius rods have been touching.
    Last time, the stabilizer had moved to the left and I loosened the mounts and re-centered the bar. I checked it just now and it has moved to the right this time.
    There are collars available that clamp around the stabilizer against the mounts to stop the bar sliding sideways. I think Whiteline makes them.
    Hope this helps.
  1. Clunk noise in rear end...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 05:37 PM
  2. Strange Noise...
    By Dazzamcgee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 04:13 PM
  3. clunk/noise in front left wheel of vs
    By vsplook in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 04:41 PM
  4. Clunk noise from the back
    By scbh81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-07-2005, 09:57 PM
  5. strange noise
    By Tony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2004, 10:37 AM
