Results 1 to 20 of 20
Thread: SRS Airbag fault
    VZ Commodore SV6
    Aug 2008
    Angry SRS Airbag fault
    Hello guys
    My car is a VZ SV6. The problem is, it shows SRS airbag fault display whenever I start. I never met across any accident or something, just started showing this message from last week. Then I took my car to holden service centre (westpoint-darra) and they said its due to high resistance in seat circuit and charged $60 for 30mins labour. They said that the error is reset. But again by evening when I started the car, it started showing the same message. I took my car to the same service station this morning and after about 1hr they said that the airbag and spring has to be replaced and it cost about 900 bucks. Somebody please suggest me if there is any other thing I can do...Thanks heeps.
    Saj
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    You could try taking it to an auto electrician and get a second opinion. Other than that my only advice is don't go to holden for services unless your still under warranty.
    VZ Commodore SV6
    Aug 2008
    Post
    Thanks mate. Here is the description of problem as per holden service centre
    "Investigated and found that the driver airbag has high resistance and requires replacement along with the clock spring. Customer to please note that the air bag may not deploy"
    Well, I don't know mate, I'm annoyed. The main reason for buying a near new car is just because I don't like to run behind the maintenance and I never expected such problem from a most common car like commodore.
    Looking forward to hear from you
    Thanks
    Saj
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    VZ Commodore SV6
    Aug 2008
    VZ Executive
    Sep 2007
    hey mate im having the same problem as you im taking mine into holden nxt week or so just hoping that its not expensive as what you got quoted.
    VZ Commodore SV6
    Aug 2008
    Hey
    It's expensive mate, they said it will be around $900. So better I will check this once again with an auto electrician. But yours may not be exactly the same, if it's just an error they can easily reset it. Anyway best of luck.
    vz wagon
    Feb 2008
    VZ Commodore SV6
    Aug 2008
    Oh....thats so sad. So what you gonna do now?
    It will be excellent if someone can suggest a place to fix it other than holden service centre. I live at forest lake-QLD
    vz berlina
    Aug 2006
    Quote Originally Posted by schteven View Post
    i just had the exact same thing happen also a week out of warantee
    I'm sure if you've had your car serviced at the same Holden dealer since you've had it they should look after you after all its only one week over .
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    its either going to be the clockspring or the airbag, have it diagnosed first & the codes reset by someone who knows what they are doing, quoting on both at once indicates they are too lazy to diagnose it correctly.
    VZ Commodore SV6
    Aug 2008
    have you got it fixed mate?
    bludeck's Avatar
    VZ Wagz
    Dec 2007
    Gold Coast
    My abs lights started doing it, so far have replace seat belt pretensioner, abs module and clockspring getting replaced tomorro, will let you know if it solves the prob
    bludeck's Avatar
    VZ Wagz
    Dec 2007
    Gold Coast
    Clockspring has fixed the problem, obviously every problem is different.
    Lucky it fixed it, worth its weight in gold and then sum..
    Also note that airbag was replaced before clockspring, problem still evident.
  15. #15
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    I agree Bob - that's a typical "replace-everything-we're-bound-to-get-it" attitude. After all, it's the CUSTOMER that has to pay for it.... Lazy fault finding - gives me the squirts!
    In fact, I would suspect the clockspring before any other bits. That's the part that's always moving, and subject to the majority of the wear.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  16. #16
    2005 VZ Commodore Acclaim
    Mar 2010
    I have a 2005 VZ Acclaim wagon. When I first bought it, the SRS Airbag Fault light would display everytime I started my car. I took it a mechanic for it's regular service and asked him to fix the airbag fault, which he did do, as the light stopped coming up on ignition. To my dismay, yesterday it begun to appear again! 2 months after I first had it fixed. At least I know now to request a clockspring replacement before they charge me for the entire airbag! Thanks very much everyone.
  17. #17
    5.7L VZ
    Jan 2010
    Nthn Beaches, Sydney
    I've never had to replace an airbag, and I do alot of work with SRS systems. Faults like this can generally be caused by broken wires (ie under seats where it moves back and forth), bad plug connections, or typically the clockspring (as it's maneuvered alot). Don't just have parts replace or request the clockspring be changed right off the bat, it may not be the problem, get it checked by an auto electrician first. Holden may make the car, but their service technicians tend to know jack all and just replace parts until it's fixed, mainly because their mechanics, not electricians...
  18. #18
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
  19. #19
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Quote Originally Posted by VzVzVz View Post
    take a hammer to the front sensor and stand back.
    problem solved.
    just buy and after market one and take the globe out of the dash then hope you never need it
  20. #20
    01 VU S Ute
    Apr 2006
    Country Vic
    I know it is an old post but I am having the same problem with my wifes 06 SVZ wagon.
    The mechanic got the light to turn off which was a few months ago but now it has started again.
    Going in tomorrow to be checked out again
    The car has only done about 33000k's - we are second owners
    How did the unfinished stories end
    Dont spam that rubbish in your signature
LinkBacks (?)
  1. SRS Airbag Fault
    By The Windsurfing VY Wagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-08-2011, 12:03 PM
  2. SRS Airbag Fault
    By adamc11 in forum General
    Last Post: 30-08-2009, 01:45 PM
  3. HELP - SRS Airbag Fault
    By MyPetFly in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-11-2007, 11:14 AM
  4. Steering Wheel Airbag Fault
    By acclaimwagonvy2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-08-2006, 03:07 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
