hmm did the smoke smell electrical?, check to make sure power wire havnt rubbed though or gone loose and contacting metal. also check to make sure the transmission cooler lines arnt leaking onto the echaust, dexron 111 burns with white smoke
check powertrain indicates an emissions related fault, you will need a scan tool my friend
try an locate the source of the smoke if you can
__________________
Like what you read, Then hit the scales
