Originally Posted by
wack
This is out of my manual.....VZ AWD Adventra and cross 8 handbook.
Disabling the RPA
On some occasions you may wish to turn the RPA off to prevent the constant warning tones while reversing,such as when a bicycle rack is fitted to the tow bar (a bycycle may be recoginsed as a close object by the RPA.)To turn the RPA on/off,proced as follows:
1.Ensure that the engine is turned off.
2.Open the tailgate and carefully remove the right-hand light trim cover with a flate blade screwdriver.
3.Locate the black harness conector mid way along the RPA harness.
. RPA off - disconnect the black harness connector.
. RPA on - connect the black harness connector.
4.Install the rear light trim cover and close tailgate
Tow Bar
Same procedure as above
. Tow bar fitted - Disconnect the white harness conector.
. Tow bar removed - Connect the white harness connector
I use the Disabling the RPA method when I attach my tow bar.And its not a genuine one its off my old cruiser,
I know this is in a wagon but it might be worth a look?
steve
