Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VZ Holden Commodore (2004 - 2006)
VZ Holden Commodore (2004 - 2006) Talk about anything relating to the VZ Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 10-11-2008, 11:53 PM
Ride: VZ EQUIPE
policehoon Executive
Default How to bleed brake lines
I have just replaced my brake pads (front and back) for my VZ with Bendix Ultimates.
My question is how do you bleed the brakes correctly especially with ABS.
I have tried the old 10 mm spanner on the bleed valve with someone pushing the brake down and constantly topping up the brake reseviour method. I am just asking if thier is a better way.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 11-11-2008, 05:04 PM
andyman's Avatar
Master Hippo.
Ride: 05' VZ Wagon, 04 Husky TE250 & 05 Husky TE450
andyman Monaroandyman Monaro
I have tried the old 10 mm spanner on the bleed valve with someone pushing the brake down and constantly topping up the brake reservoir method. I am just asking if thier is a better way.
1. aslong as you have a small tube over the end of the nipple that seal well, and the hose goes at least 2 inches high than the caliper (to stop air getting into the lines)
2. get someone to hold the brake pedal down, then crack the nipple, then close up the nipple before you release the pedal.
3. this is fine with abs,
__________________
VZ Wagon - Starting to get there
>>>>>HERE<<<<<
Black 18z, Hell Yeah
My New 05' Husky TE450
--===-- My Old 04' Husky Te250
Quote:
Originally Posted by Hamish & Andy
Whats it like firing a big gun on a tank?
"like having a massive penis that shoots fireworks"
Like what you read, Then hit the scales
  #3
Old 14-11-2008, 06:18 PM
bpottz's Avatar
Donating Member
Ride: VT Berlina
bpottz Executive
that or you can do a gravity bleed if your stuck on your own, did one myself today.
__________________
My 1998 VT Berlina - Lowered, 18's, Leather
http://forums.justcommodores.com.au/...tml#post863216
  #4
Old 14-11-2008, 06:22 PM
LightningVP's Avatar
Happy New Year
Ride: 1992 VP Lightning
LightningVP has disabled reputation
What is a gravity bleed?
  #5
Old 14-11-2008, 06:26 PM
howepower's Avatar
Donating Member
Ride: vc commodore sl
howepower Executive
gravity bleed happenes because the resivoir isx higher then the bleed nipple so it falls out the nipple
__________________
  #6
Old 14-11-2008, 06:29 PM
Happy New Year
Quote:
I still don't get it :S what resivour? The one in the car?
  #7
Old 14-11-2008, 06:31 PM
andyman's Avatar
Master Hippo.
Quote:
yes, on the master cylinder, it holds the fluid,
all you do is hook a pipe onto the nipple direct it into a bucket and crack the nipple, it will only drip out, so it take a fair long time
__________________
>>>>>HERE<<<<<
  #8
Old 14-11-2008, 06:33 PM
Happy New Year
Oh ok....I see thanks
  #9
Old 15-11-2008, 11:23 AM
bpottz's Avatar
Donating Member
Ride: VT Berlina
bpottz Executive
really doesnt take that long, if you give it a couple of turns after cracking it it goes a bit faster, each caliper takes less than 5 minutes?
i dont run a hose from the nipple, i just let it drip out, i just make sure i give it a rinse with water afterwards.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VN brake lines IvegotaCommy VN - VP Holden Commodore (1988 - 1993) 12 18-09-2008 08:02 PM
Braided Brake Lines? cpbait General 7 11-01-2008 09:50 PM
Brake lines - rubber vs braided ephect General Discussion 12 18-04-2007 10:41 PM
Brake lines Bax VL Holden Commodore (1986 - 1988) 3 13-09-2006 11:44 AM
Brake Bleed Nipple Stripped Demons1964 VB - VK Holden Commodore (1978 - 1985) 2 09-01-2006 03:14 PM
Loans | Myspace Layouts | Credit Cards | Debt Consolidation | Wohnung Berlin | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
