Quote:
Originally Posted by Simon W
ok , so how do i go about fixing the tie rods or wheel bearings? Is the rotor and hub all one piece, and the 3 allen key bolts at the back are they to remove the rotor? Any help would be sooooo good.
Thanx
The rotor and the hub assembly, which includes the wheel bearings, are separate parts.
The three allen bolts hold the hub assembly on. The rotor is clamped betwen the wheel and the hub. It should be obvious if/when you pull the wheel off.
If you decide it is necessary to replace the hub/wheel bearing, it is fairly straightforward, bearing in mind that there are safety implications if you get it wrong.
The brake caliper needs to be unbolted and supported so as to avoid damaging the brake lines and fittings. I am not sure if the brake water shield needs to removed but I think that the ABS sensor, if applicable does. Then the three allen bolts.
Those will probably be difficult to undo because they are installed using a threadlocking compound. They should be reinstalled with it also; Loctite 242 or similar, the old stuff cleaned off the threads first.
