Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VZ Holden Commodore (2004 - 2006)
VZ Holden Commodore (2004 - 2006) Talk about anything relating to the VZ Holden Commodore.
Reply
LinkBack (1) Thread Tools Display Modes
  #1
Old 20-11-2008, 04:48 PM
trident_12's Avatar
Ride: VZ Wagon 05
trident_12 Executive
Default Changing the steering wheel...
No, ive used the search button & have found the page. But i do have one question.
Before i searched on this site for removal/fitting instructions i ran around to the local panel beaters (x2) & both have said that i have to get the computer reset RE airbag disconnection. ??? what the? sounds like a scam to me. anyone else come across this before? this scam will cost me $120 if i get them to do it...
i dunno what to believe.... i reckon i just do it meself me thinks... why does the computer need to be reset????
thanks noob.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 20-11-2008, 05:05 PM
MEANVY's Avatar
Superhero-in-Training
Ride: VY Commodore Exec.
MEANVY Executive
i wouldn't think the computer has anything to do with it, i thought the airbag had something to do with pressure or something?
i was just about to swap my steering wheel over to the SS type and the thread i read said nothing about it, and it had photos of him with the steering wheel off...i dunno sorry. SOMEONE HELP THE GUY OUT!
__________________
What's the definition of mixed emotions?
When you see your mother-in law backing off a cliff in your new clubsport.
Mitch's Ex-police VY Commo
Quote:
Originally Posted by VT SERIES II View Post
if a stripper said it , it MUST be true!!!!
.....I still think its dirty .....
  #3
Old 20-11-2008, 05:31 PM
Torquative's Avatar
go JCCC NSW
Ride: VZ Acclaim and SX6 Adventra
Torquative has disabled reputation
okay ive done this both numerous times successfully and once unsuccessfully
If you disconnect the battery, take the keys out of the ignition then remove the air bag module (horn pad) and take note of the way the connectors connect you should be fine.
The one time I set off the SRS it was either I had the key in the ignition with the battery connected, or I put the yellow connector in the wrong way, because either way when I started the car it came up with an SRS fault which I had to have cleared. I was in a rush and realise I hadnt followed my own advice with this one.
Once an SRS fault is set it HAS to be cleared by tech 2, the theory and law being that an SRS fault can be a potential danger so if the car has recognised a fault, even if it comes good, a dealer (ie who has tech 2) has to have the car back to inspect it and give it the all clear.
If you dont disconnect the battery the theory is when you disconnect the airbag the car will detect it and warn you at next start up as the BCM (or some module) is still active, but I think this is bollocks, I think the issue was I put the connector in the wrong way so when I started the car and it scanned for the air bag it couldnt find it.
Either way had to get Holden to reset it after an argument
But that said Ive done it 5 or 6 times now to VZ's in the carport without an issue, just disconnect the battery and make sure the keys arent in the ignition!
another warning too is if you do fcuck up you can potentially set off the air bag, which would hurt the face if you copped it, but Ive never heard of that happening - just something to keep in mind.
  #4
Old 20-11-2008, 05:34 PM
MEANVY's Avatar
MEANVY Executive
ok cheers for that.
shall get the hockey mask ready for this weekend....
__________________
  #5
Old 20-11-2008, 06:09 PM
trident_12's Avatar
Ride: VZ Wagon 05
kool, thanks for the advice fellas. *Puts on hockey mask...
  #6
Old 20-11-2008, 07:27 PM
juzo's Avatar
Appy-polly-loggies
Ride: 05 VZ SS M6 / 02 rodeo td dual cab
juzo Caprice
Yes, it's a scam.
I've done heaps of them now and never had an issue.
__________________
How important do people have to be before their murder becomes an assassination?
  #7
Old 21-11-2008, 02:41 PM
davo43's Avatar
Another google mechanic
Ride: VZ Executive Wagon
davo43 Executive
I did mine (following the instructions on this forum) with absolutely no hassles... Well, nothing permanent anyways...
__________________
Stock Odyssey 2004 VZ Executive Wagon
My Intro Thread
  #8
Old 21-11-2008, 04:13 PM
Phreddy's Avatar
1st VZ with a blue dash!
Ride: '05 SV6 M6
Trade Rating: (0)
Phreddy ClubSportPhreddy ClubSport
The only time you will have problems is if you turn the ignition on with any part of the airbag system disconnected. The system does a self-test on "boot-up", and if a sensor or airbag is not detected the fault is logged. And yes, as mentioned, it MUST be reset by the dealer with a Tech2.
You can have the whole lot unplugged, as long as it's all securely connected before the ignition is turned on again.
__________________
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
Click the scales if you like - or not - what I have to say...
  #9
Old 25-11-2008, 04:29 PM
trident_12's Avatar
Ride: VZ Wagon 05
cool! thanks for the advice guys! much apprciated
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forums.justcommodores.com.au/vz-holden-commodore-2004-2006/85777-changing-steering-wheel.html
Posted By For Type Date
WASALive ! Steering wheel - Just Commodores This thread Refback 04-12-2008 04:56 PM
Thread Thread Starter Forum Replies Last Post
Changing steering wheel in VR dawg VR - VS Holden Commodore (1993 - 1997) 12 30-12-2006 05:19 PM
how to changing steering wheel cover kietysack VZ Holden Commodore (2004 - 2006) 3 25-02-2006 12:16 AM
how to changing steering wheel cover kietysack VZ Holden Commodore (2004 - 2006) 0 19-02-2006 08:09 PM
changing steering wheel TriK VN - VP Holden Commodore (1988 - 1993) 13 11-12-2005 11:14 AM
Changing steering wheel. scott8888 VN - VP Holden Commodore (1988 - 1993) 9 30-06-2004 12:20 AM
Credit Counseling | Loans | Mobile Phone | Retro Football Shirts | Skateboarding | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
