| VZ Holden Commodore (2004 - 2006) Talk about anything relating to the VZ Holden Commodore. |
22-11-2008, 02:48 PM
Another google mechanic
Ride: VZ Executive Wagon
I've stuffed the car - help needed urgently!
Ok, so today I decided to change my accelerator pedal and it turned into a huge job - I had to remove half of the dashboard including unclipping and moving the "body control module" out of the way (I DIDN'T UNPLUG IT!).
After removing the old accelerator pedal and replacing it, I put everything back in its place and started the car.
It's giving me an error message saying "SAFETY MODE - PERFORMANCE REDUCED" followed by "SERVICE VEHICLE SOON" and it's sluggish and won't rev past 4,000rpm!
Do I have to pay my retarded Holden dealership to fix this???
HELP!!!
22-11-2008, 03:01 PM
Made it to 2009
Ride: 91
The poor car has logged an error code of some sort. Have you bumped a sensor?
I'm guessing here but the peddle in the VZ is electronic so I'd suspect that the sensor has come a gutser some how.
22-11-2008, 03:31 PM
Master Hippo.
Ride: 05' VZ Wagon, 04 Husky TE250 & 05 Husky TE450
which pedal did you replace it with, i have heard that the ss pedal with the silver pedal will not work correctly with the v6's,
also was the battery disconnected when you removed the pedal, i think the pedal may sort of active when the ignition is off, the throttle also fully working the the key is on the accessories
__________________
Like what you read, Then hit the scales
22-11-2008, 03:44 PM
I was assured it would work with an alloytec... The car is responding to accelerator, it's just in "safety mode"... I didn't think I would need to disconnect the battery but now I wish I had...
I have to drive this car now for two days with no balls...
22-11-2008, 03:46 PM
Made it to 2009
Ride: 91
Can it be reset by pulling the main fuse like in the VN?
22-11-2008, 04:11 PM
you're a towel
Ride: VZ SS 5.7 M6
I doubt that it's related to the pedal being removed and the ignition on. When I was running the power wire in my VZ SS I had the pedal assembly off and turned the car to "On" to wind up the windows, and it threw a SVS warning, but when I reconnected the pedal again and started her all the warnings had cleared and she was sweet.
I wonder if he hasn't broken a wire, or dislodged the connector to the BCM when moving it around?
22-11-2008, 04:23 PM
Master Hippo.
hmm did you try disconnecting the battery at all, dislodged wiring is possible but im sure ive seen it done and it didnt work,
was the assurance it would work from a holden dealer or the guy you bought it off.
__________________
22-11-2008, 06:48 PM
Ride: VN-V6/2005 SV6
ive noticed that my 05 sv6 auto only revs to 4 grand when in neutral... but revs higher on the road
22-11-2008, 07:06 PM
Currently on leave :D
Ride: Black 2005 VZ S Ute
Quote:
Thats standard, probably to stop people thinking that they can do a burn out by revving the hell out of it and dumping it into drive.
23-11-2008, 08:13 AM
go JCCC NSW
Ride: VZ Acclaim and SX6 Adventra
where did you buy the pedal from and is it for a manual?
Ive had this exact same thing. I brought a pedal for a manual SS and installed that into my auto acclaim with the 175kw. Same issue, safety mode, it brings up about 7 different errors when you start up, doesnt shift from 1st very easily yadda yadda yadda.
If your not sure - remove the pedal completely to check.
The box bit on the pedal where the car plugs into the pedal itself has some torx bits from memory, remove them so you can take the cover off.
The manual pedal says something to the effect of Holden Gen III whereas the autos just say Holden on the PCB breadboard.
If this is the case I just swapped the pedal and shaft themselves. The shaft comes out of the board completely and easily, I cant remember how its held in but its fairly straight forward and you'll understand when you see it.
I would suggest taking out the SS pedal to pull apart first so you understand coz if you break something at least you have the original pedal to put back in. Once you put the original pedal back in (or the original box bit back in) the error goes away,
If you have a manual pedal for an auto Holden will charge you at least an hour labour to diagnose, then tell you sorry this pedal isnt compatible with this car, pay 300 bucks for a new one.
Also the easiest way to take it out without removing half the dash and BCM is to remove the plastic bracket that the pedal is screwed too. It uses 4x smallish nuts, just get a long reach socket. Cant remember the size, its about a 8 or 10 mm or something. Undo the 4x nuts and the whole yellowish bracket comes out. Then just unscrew the 2 bolts that hold the pedal on while its outside the car. Then theres no need to be near the BCM. Its a bit fiddly but Ive done it to a few VZ's now.
Good luck
23-11-2008, 08:43 AM
you're a towel
Ride: VZ SS 5.7 M6
Quote:
Makes you wonder why they'd have different versions, of what is essentially a potentiometer with a stick attached to it.. makes our life harder and presumably increases their design/production costs?
This is good advice, those nuts are pretty fiddly to get off/on, but probably much less fiddly than removing half the dash. That's how I got mine off.
23-11-2008, 11:31 AM
Master Hippo.
thats where i knew they wearnt compatible, it was matt lol
__________________
