I have a problem with the dash on the VZ wagon.
Nothing is working (indicators, head lights etc are fine).
I checked the fuse and its all good, any ideas?
By saying nothing on the dash is working do u mean just the dash cluster is not working? or is it something else.
Could be:
loose connector somewhere
Fault with a relay
The Blue One
have you checked the fusable links, there the big mofo fuses that look like relays,
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Yeah the dash cluster.
I checked all the connections, fuses & relays all looking good, I bought home the computer and checked it, said it cant communicate with it and said "Instrument Data Lost". Lights & indicators work, no speedo, temp, fuel, screen etc all completely dead.
Its going back to the dealer tomorrow. Trust something I cant fix to go wrong with it.
Never mind it seems to have fixed itself...
did you check ALL of the fuses, i had a similar problem where the speedo would not light up, ended up being a random fuse for some other thing :S
