Hi guys my car started telling me to service engine oil today when i start or turn my car off does this mean that i just need to change the oil
if so how do i remove this message once the oil has been changed??
Try this,
hold up and down arrow buttons, turn ignition on, wait for confirmation, then hold set until it says its clear.
The Blue One
ta mate fixed it guess i should change the oil on the weekend and recommendations for oil to use ?? 05 VZ exec
I've been using Nulon 10W40 (I think??) full synth for my last couple of changes. Seems like nice enough oil, but I did get a little evaporation over a time. (I change my oil every 7500Ks now) I say evaporation, because it's not leaking it, and as far as I know it's not being burnt either - exhaust is too clean for that.
Some people will say to only use Mobil 1 - Meh, well it's good oil - but it's a damned rip-off! And with the Alloytec sump capacity at around 6.5 litres, a change with Mobil 1 is getting pretty spendy! I get a 6L container of Nulon for about $55-60, and an additional litre bottle to top it off. Gives me a half litre to top it up with later.
Make sure when you change the oil to do the filter as well. The filter in the Alloytec is a pretty poky little thing - not all that much room for the filter media itself..... so I don't see it being as efficient over longer periods as a bulkier one. They're cheap anough anyway from Supercheap or Ricebarn....
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
thanks guys
what about Castrol Magnetic? Is it good?
i work at holden and the service engine oil light needs a reflash to get rid of it its a over seas thing and not ment to come on and use 10w30 oil 4 the 3.6s and we use magnetic
We had the service oil light warning on my son's VZ. If you look for the instructions on how to clear this message you won't find it. You have to use the same process as when you clear the service interval reminders.
The funny thing is, whilst my VY service handbook tells you how to clear these messages, the VZ one doesn't.
Nothing needs reflashing - whether you work at Holden or not, you have bad info there I'm afraid....
i had the same thing happend to my vz the other day now i just got it fix yesterday and i went to holden and they fix it its something to do with the computer it cost about $85 its not got nothing to to do with the oil its just the reset something on the computer.
Unfortunately vzchick, they ripped you.
(unfortunately becoming more typical when a lady brings a car in - they think they can tell them anything. A mechanic quoted my ex sister in law $65 to replace a headlight globe - standard H4 - but claimed it was more expensive because it was a Celica....)
You can reset those service reminders yourself through the trip buttons. Unfortunate that you didn't have a look around here before you took the car in....
(there's a bunch of threads describiing the procedure)
hmm sorry phreddy but the "service engine oil", is a mistake on holdens behalf, "service engine oil" is meant for over seas models, the message for australian cars is only, say "30,000km service due"
if you want it fixed push for it to be done under warrenty even if its out, because its very much a warrenty item
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
yer thats right andyman
mate i use 5w 40 magnatec and have done 20 or more services since iv owned it at 52k with no dramas its the only oil id use plus i get it for free at work
