Two mornings in the last week and a half i have gone to start the car to go to work and turned the key and it didn't start. All accessories came on as usual but it didn't start, and got a message on the computer displaying "service vehicle soon." I've then turned the key to off and tried starting the car again and no worries.
Anyone know whats up?
It's not due for a service for another 6-7000 kms.
It's a 04 SV6 by the way.
Thanks in advance
I had the same problem. It turned out to be the metal ring that the key head comes in contact with at the ignition. Had this replaced and haven't had a problem since.
clean your battery terminals aswell
well service vehicle soon means it has a not emmisions related fault coded logged,
id start by disconnecting the battery, than clean the metal ring on the ignition barrell, just levering it out a little aswell, clean the metal contact on the key head, and while your there clean the battery terminals and reconnect, see how it goes.
is the key head still operating correctly?
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
doesn't come up all the time though...
yeah it is.id start by disconnecting the battery, than clean the metal ring on the ignition barrell, just levering it out a little aswell, clean the metal contact on the key head, and while your there clean the battery terminals and reconnect, see how it goes.
cheers guys will try what you suggested on the weekend
don't disconnect the battery unless you have the security code for the sterio system
