Results 1 to 6 of 6
Thread: Cigarette lighter connections
    vz berlina
    Aug 2006
    Default Cigarette lighter connections
    I just bought a 3 cigarette lighter and USB adapter,its going to fit into the compartment under the radio and will be hidden when the door is closed.
    I want to connect it to the plug for the smokers pack but before i start i want to know exactly where it is.
    3 Ways Car Lighter Cigarette Charger Adapter USB Port - eBay Accessories, Interior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 27-Nov-08 00:00:46 AEDST)
    VZ SV6
    Aug 2008
    mate ,
    plug located by removing fusepanel trim then the trim on driverside from centre console then right in front of you, under the radio you will see a white connector clipped into the frame work. so with a some pliers squeeze 1 of the lugs so u can release the plug. then you will see 3 pins im sure the top left one is negative the top right is 12v on accesories or ignition and bottom horizontal pin is 12v when parker/dash lights come on. i used that to hook up a few neons in footwells.
    Quote Originally Posted by commodore2004 View Post
    vz berlina
    Aug 2006
    Quote Originally Posted by baracuda View Post
    mate ,
    thanks i see the same one in Harvey Normans new catalogue was $39-95 .
    bloody crooks
    vz berlina
    Aug 2006
    I Got the lighter adapter today and installed it ,had to pull it apart and route the cable through the back of the unit, now the MP3 player is out of the way.
    Attached Thumbnails Attached Thumbnails Cigarette lighter connections-pictures-321.jpg   Cigarette lighter connections-pictures-320.jpg
    VZ SV6
    Aug 2008
    nice one looks good and concealed.
    no worries with finding and wiring up the plug?
    vz berlina
    Aug 2006
    I found it OK but it was dead, so i hooked into the other cigarette , There must be a fuse or some thing to activate that plug , but its up and running .And it fits like a glove exactly the right size .
    thanks
  1. Cigarette lighter in VT
    By Travelling Phil in forum Electrical Wiring / Questions
    Last Post: 25-07-2011, 09:41 AM
  2. VY Cigarette Lighter Socket
    By pedrod59 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 05:15 PM
  3. Cigarette Lighter
    By jono_vp08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 10:42 PM
  4. cigarette lighter fus
    By vg91ute in forum Electrical Wiring / Questions
    Last Post: 02-01-2008, 08:12 PM
  5. Cigarette Lighter
    By vs_commodore_guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 03:54 PM
