Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: How to drive an Alloytec
    97 VT Acclaim
    Feb 2005
    Arrow How to drive an Alloytec
    OK, just bought a VZ (upgraded from VT). I had read on a few threads peeps talking about 'learning to drive a VZ' or 'learning to drive an Alloytec'.
    What do I need to know? If there is a thread already, can someone plz link me.
    Idiocy - Never underestimate the power of stupid people in large groups
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    andrewmac's Avatar
    andrewmac is offline Not to be trusted
    S2 VE SS
    Jul 2005
    Well Really all depends on whether you get an auto or manual.
    You see with an auto you have 2 pedals, 1 is commonly refered to as an accelerator (makes you go) and the other a brake (makes you stop).
    When you have a manual you need to press on a third pedal known as the clutch pedal, you need to release this slowly while using the accelerator to make the car go and push it in when you want to change gears
    Now enough of being a smart arse
    Basically I think people are refering to the characteristics of the alloytec motor which is basically that it develops its power higher in the rev range than the ecotec did.
    So if you want to get power out of them you need to keep your revs up a bit.
    No real secret or anything to it, if anyone else knows better please enlighten us cause I may be way off.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    i think im responsible for this statement so i better spill i guess.
    1. if you want a good launch and acceleration, dont just drop your foot to the floor, the computer will go nah and gradually bring the power through, i find if you hit the throttle about quarter to half throttle, it will pick up and respond much better,
    2. if you like the little bit of wheel spin occasionally, dont plant it number like number 1, it wont do it easily off idle, doing it coming out of a little corner or already rolling like 10km/h makes it much easier,
    3, if you go into the secondary trip computer function, (holding mode+set turning ignition on) flick through to l's per hour readout, you will find backing off the throttle a little bit will keep you at your speed still, but will save you a fair bit of fuel in the long run, you can see the difference in the read out on the computer,
    4, if you want more power get a vcm suite tune, its worth it.
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    FG XR6T Ute manual
    May 2007
    Brissy
    like you stole it
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    VY II SS
    Sep 2008
    Do you really need a thread on how to tell you to drive a VZ?
    Learning to drive comes with trial and error, and experience.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    i think they are refering to drive by wire.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by burnz View Post
    hit the nail on the head, ETC allows the computer to control the power output by a massive amount, you have to be sneaky with it, or as i said get vcm and remove all torque management abuse mode parameters etc etc
    Sep 2008
    FG XR6T Ute manual
    May 2007
    Brissy
    A manual will fix all those problems but you just have to pray the clutch doesnt give up
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by fuzzy2308 View Post
    so no skid or line lockers and circle work? just curious
    manual yes, auto yes but more trickey
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Troy711 View Post
    ^^^ I beg to differ... an auto V6 can light up the rears fairly easy.
    i know it lights up real easy, my wagon still spins 18's easy, but will it do a standstill, thats what i thought other person was referring to,
    cause the ecu limits rpm when brake is applied
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
  15. #15
    Sep 2008
    Quote Originally Posted by andyman View Post
    thats what i meant
  16. #16
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    thats what i meant
    in a vz if you cruise along and the engine is doing say a constant 3,000rpm, apply the brake and it will drop the revs to 1500rpm, you can put your foot flat to the floor, it wont rev, take your foot off the brake and the car will launch back up to where the accelerator is at
  17. #17
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Mine can quite happily rev 4-4.5k on brakes no worries (auto) and launches ok, but same issue, hard to do stand stills, can do launches with wheelspin aswel but requires you to be quick on the accelerator and then quick off the brakes at the right revvs too. If you want to get sideways out of a corner, hit the GO pedal about a second or 2 before you normally would with a wire-driven throttle and pray you have LSD coz they do kick out nicely, but requires a short build up of revvs. Basically just play around with the revs until you are comfotable with it all. Also if you hammer the accelerator before a corner and apply brakes, you build revvs and the computer senses you are in "fun mode" and keeps the revs high for about 10 secs, which when exiting a corner can be used either mid apex (for slide) or after so you can power out of a corner. Just things I have picked up so far Anyone else find anything similar ? (oh, LSD is sooooooo much fun in the wet with these cars too find yourself in a little trouble and nail it, straightens up nicely.)
    Me? I'm the guy who does his job ... you must be the other guy ...
  18. #18
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    yeah, that only happens when your in D, wont happen in active select, its annoying when you plant it and then back off, ie turning into heavy traffic.
    Chev badges are an instant fail
  19. #19
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    yeah agreed, does only happen in D (D for "Drag"). Would be helpful if you could just enable the constant high-revving when you want it, not just when you stab it heh
  20. #20
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Ewok View Post
    lol at the single spinner, you'd get mine spinning like a demon, then it would kick over and spin the other side and almost throw you into the gutter, after putting the lsd in, its so much more controlableable and doughnuts are **** easy lol,
  21. #21
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Single spinner? Mines LSD diff. what ya on about ?
    heh, reminds me of the time me mate in his TT Soarer tried to drift out of a 2 lane roundabout with his open-diff .... 180 up a kurb anyone? Hillarious watching it in my rear view mirror .....
  22. #22
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    no i was just laughing about single spinners in general, i know yours is a lsd
  23. #23
    VZ Crewman S
    Oct 2008
    What about the 6 manuals? I find it hard to get much power off the line even when heal toeing the brake and accelerator. I generally get her up to 2 - 3grand then drop the clutch (to attempt wheelspin and not ver much wheelspin) or drop it a little slower to keep traction. does any one reacon its due to the dual mass flywheel?
  24. #24
    FG XR6T Ute manual
    May 2007
    Brissy
    Mate be careful when dropping your clutch from a standstill. I only did it a few times and my clutch is pretty ****ed. Im not sure about the DMF but i know the clutch isnt very strong at all which is a big part of the problem
  25. #25
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    we have a vz and its a really nice car impuluse blue SV6 6 speed,it has now 40,000 on the clock and i gave it to my wife to drive,i will have my vn s pack 5 speed any day,i cannot stand anycar that has delay when u take,it will rev to 7k easy but at an intersection taking of its junk,my vn on gas would blow the doors of it when it comes to take off
  1. To all Member That Don't Drive A Commodore, What Do You Drive:
    By Evolution_Ends_Here in forum The Pub
    Last Post: 07-12-2008, 05:40 PM
  2. what drive "D" do u guys drive in
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2008, 09:45 AM
  3. 3.6 alloytec
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2008, 07:22 PM
  4. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
