I wanted to change my Diff oil in my VZ SV6 but don't know how. Any clues in how to do so and what do I need.
I tried looking everywhere for this info
Thanks,
Shaun
Thank You !!
The Blue One
Paul, I'll be changing mine shortly its just clocked over 130 000 kays and oil is oil, it breaks down!!!
same as the coolant debate, its supposed to last 3 years or 5 years or something but its still a liquid ...
Im house bound today and couldn't think of much else to do so thought I would do radiator flush, oil / filter change and diff oil change.
Cant hurt
The Blue One
I had my diff oil changed in the VT..It's the worst thing I ever did the *&^*^%$heap hasn't stopped whinning ever since.
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
its interesting that the diffs whining, maybe the oil wasnt right?
A whiny diff isnt good, and its the oil inside the diff housing that forces the pinion and drive wheel together ...
lol love the technical response Andy
BUT I still stick by my comment, a whiny diff aint right unless its a Falcon taxi coz then all Im worried about is the damn thing getting me home![]()
The Blue One
All changed and all sounds great !!
Will try and find the oil package and let you know what i used
well if you use castrol, you use SAF-XA in lsd's Without the additive that holdens says cause its allready in the oil, or if its a single spinner LSX90, SAF-XA can be used in the single spinner fine, but seals may start to leak after a while cause they dont have syntheitc oil type seals in them
Oil breaks down / gets contaminated over time. I just had my diff & auto serviced (05 sv6 62k on the clock) and the change in the car is great. No more binding up ( clunking ) in the diff and the lsd works better now. The auto will hold the car on a steep hill no throttle or brakes without rolling back at all. The gear changes are crisp now not that it was ever bad but I just think you should get them done on a regular basis. I prefer to get things looked at and serviced before they brake down.
The guys at workshop ( Preston autos & diffs in Melbourne's north) did a great job.
Does anyone know how often Holden says in between services? I can't find it in manual.
Anyhow thats just my 2c worth.
The Blue One
Go the Penrite Sin gear 70 or 80. Top stuff.
