Results 1 to 9 of 9
Thread: Rear Spoiler Install Assist
    VZ EQUIPE
    Oct 2008
    Default Rear Spoiler Install Assist
    I recently purchased a rear Spoiler for the VZ (appears to be a VZ SS replica) off E-bay. Now I have attached it to the rear boot and need assist in the wiring of the rear brake light on the spoiler.
    Has anyone done this and can provide assistance, provide knowledge on how to correctly wire up the rear brake light.
    I have attempted to do it, but in the process blew a fuse for the brake light.
    Thanks in advance
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    VZ Calais, VS Exec, VL Exec
    Mar 2005
    Mandurah W.A.
    with wiring the brake light up, its best to run the spoiler wiring off the eye level brake light in the back window, to gain acces go through the boot to get to it
    then using a test light check for which wire lights up with the brake applied, which will be positive
    then get the wiring from the spoiler and connect the red wire from that to the positive wire on your car, and connect the negative to the other wire thats there
    before you put everything back togethor make sure to check it all works, if it does then put it all back togethor
    as for blowing a brake light fuse, im not sure how you could have done that other than wiring something wrong
    Supercharged VU SS
    Feb 2006
    The Shire
    dont all cars have the spoiler plug already there, just like all car have the rear window brake light wiring, even if they have the wing.
    check on the inside of the boot lid there should be a small 2 pin plug, on the drivers side.
    i know my brorther berlina has it and it doesnt have a spoiler
    VZ EQUIPE
    Oct 2008
    could someone take a picture of what plug I am looking for in the boot area to install the brake light wires.
    I have looked and located a pin on the right side behind the carpet. I put a meter on it and it shows 0.012 ohms.
    I doubt this is sufficent power to run the brake light on the spoiler.
    2010 Voodoo Sv6
    Sep 2008
    Maybe because ohms is a measure of resistance and not voltage, current or power...
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
    VZ EQUIPE
    Oct 2008
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I think you are looking in the wrong spot. The wiring connector you need is up inside the bootlid. Look inside the openings just to the right of centre inside the bootlid. You will see the wiring for the boot release running from the lock towards the front right corner of the bootlid. Near it is a black connector clipped to the inner skin of the boot with two wires leading into it.
    That is the spoiler light connector. You won't confuse it for any other connector as it is the only one sitting there doing nothing, and it is quite small. Your spoiler will need to be connected the right way round or the light won't work.
    Good luck.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Quote Originally Posted by policehoon View Post
    Okay so I am not a auto electrician, 0.012 volts then.
    do you have the multimeter set on the right scale? (there's a different 'multiplier' setting for each measurement type)
  1. Rear Park assist
    By therobbos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-08-2008, 02:43 PM
  2. rear spoiler or not
    By ned in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2008, 10:39 PM
  3. anyone have a vs rear spoiler
    By vnwagon91 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2007, 09:54 PM
  4. Anyone know where can i install the electric spoiler?
    By redgts in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-10-2006, 09:35 PM
