Results 1 to 19 of 19
Thread: VZ fuel filter direction?
    coastvl's Avatar
    coastvl is offline Member from the dead!
    VZ EQUIPE six
    Jun 2003
    Hervey Bay
    Default VZ fuel filter direction?
    Hi, This is a dumb one. I have replaced the fuel filter in my VZ and I think the filter may be around the wrong way.
    Which end does the "out" end go on? The filter is a Ryco BTW.
    The "T" piece end or the single line?
    I'm feeling like a right twat so go easy.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    the out goes towards the t piece
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    05 VZ Commodore Equipe
    May 2007
    coastvl's Avatar
    VZ EQUIPE six
    Jun 2003
    Hervey Bay
    coastvl's Avatar
    VZ EQUIPE six
    Jun 2003
    Hervey Bay
    I'm back.
    Since installing the new filter the mileage on the dash has gone from 12's to 15.5 or more. It won't budge any lower. What the hell happened? Been through 2 tanks since the change now.
    Thanks.
    May 2007
    I don’t see how a new fuel filter could increase fuel economy. Did you do anything else to the car when you changed the filter? Driving with the AC on? Low tyre pressure?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    did you disconect the battery, if you did, it rest the fuel consumption average, so it wont come down until you do more long distance driving or more driving in general
    also make sure there isnt any leak, but ive never seen one of those fittings leak yet
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    dont forget thats only an average reading too, if you do lower speeds it goes up ... and is fairly pointless. I can thrash mine and get a better reading then country driving because the average speed goes up ... go figure.
    I can have mine reading about 4.9 litres per 100 kays if I reset it on the motorway and have cruise control set, but as soon as my speed drops it goes back up and doesnt come down, as soon as it registers a lower speed the AVG SPEED goes down and fuel consumption goes up.
    I reset mine after each refuel and despite the "average consumption" reading, always get about 600 kays to a tank.
    Its a flawed system to begin with. The same way you can get "fuel very low" warning on yet you still have 13 litres in the tank which is good for another 100 kays of driving even in peak hour conditions ...
    I suggest resetting the average fuel consumption and drive the highway for 10 mins, then you'll see it drop
    coastvl's Avatar
    VZ EQUIPE six
    Jun 2003
    Hervey Bay
    Thanks guys. Thats pretty much what I have done. It seems to be sitting on 14 with a 5 minute cruise at 100k's. So it's getting there.
    Thank you.
    vz crewman ss thunder
    Feb 2009
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by attila john View Post
    hello, where is the FUEL FILTER on a ss crewman thunder???
    in tank strainer,
    silly cause it isnt a filter as such,
    Feb 2009
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    sounds stupid but where is/ what is the tank strainer???
    its attached to the bottom of the fuel pump, the fuel tank has to be dropped out of it
    Feb 2009
    Feb 2009
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    is it easer to drop the tank or take the back chassis off??
    yes its a pain, im trying to remember the tank in the crewwy, im pretty sure you have to take the tailshaft out, up to you whichever way you do it,
    i havnt dropped a crewman tank yet so i cant say i know how the filter setup runs, i have been told before that there is no fuel filter reference listed on holden parts, only just the strainer that is fitted to all pump in cars
  17. #17
    Feb 2009
    thanks for the answers, one other quick question, do you know how to change the spark plugs on the 6.0L gen4 motor, i am having trouble taking the spark plug lead off, is there a certain way for it to come off??
  18. #18
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    grip the plug on the lowest end of the lead, pull it firmly and directly back, then, undo the plug and swap it with the new one, make sure you dont overtighten it, its going into an aluminium head, if youve got some lying around, smear a little anti seize on the threads of the plugs
  19. #19
    Feb 2009
    Very much appreciated mate. thankyou
  1. Fuel Filter How-To (VN - VS)
    By Darren in forum Holden Commodore How-To's
    Last Post: 18-03-2011, 09:53 PM
  2. Fuel Filter
    By plazma in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-02-2009, 08:14 PM
  3. doing fuel filter, what do i need?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2008, 05:40 AM
  4. Fuel Filter
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2006, 05:58 PM
  5. fuel filter
    By JoeCamel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:01 PM
