Results 1 to 7 of 7
Thread: alloytech coolant drain?
    VN-V6/2005 SV6
    Jul 2005
    Default alloytech coolant drain?
    does anyone know if there is a drain plug on the block of the alloytech
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Most likely is mate, but not sure where.
    All i did when i drained the coolant was undo the radiator drain plug. When looking at the top of the radiator its on the right hand side at the bottom corner.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    there is welsh plugs, but i doubt there will be a bolted bung
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VN-V6/2005 SV6
    Jul 2005
    when i drained the coolant out... the most i could get was about 5-6l...there should be about 11l in there....there must be some other drain some where
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by crewzincool View Post
    that sounds about right,
    if you want to to a real coolant flush you should remove the thermostat and them flush through backwards, but depends if you that keen considering there at the back of the engine
    VZ
    Feb 2007
    just did mine today had the same problem only got about half out?runs a bit cooler though which is good
    VZ SV6 05
    Sep 2008
    yeah mate i did mine today aswell u can use the little knob that can be unscrewed by hand, on my vz was on the left front, but u can just disconnect the radiator hose to speed up the process, and yes u'll only drain about half of it out, is normal
  1. drain coolant
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-03-2010, 09:16 PM
  2. how do i drain my coolant?
    By ShIbBy_industries in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 05:04 PM
  3. coolant drain
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-07-2008, 10:04 PM
  4. Alloytech coolant?
    By crewzincool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2008, 08:36 PM
  5. Coolant Drain
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2004, 05:41 PM
