Hi,
I have a VZ S ute with SS body kit and front fog lights that aren't wired up. I have brought the genuine pull out fog light switch and the fog lights have plugs hanging off them.
Will the wiring loom have the associated wiring in it or will I have to get new wiring installed?
What about the relay?
Regards Ryan
my understanding is the wiring should be there, all you need to do is plug in the switch, relay and fuse, and connect the fogs lights up.
in the fuse box in the engine bay, does the relay spot for fog lights have copper terminals in the base, if it does, fit a relay there,
if as you say there is wiring in the front bar area for the lights hook them up, the pop out the old light switch, plug in the new switch, then see if they work, you will also need atleast the parkers to be turned on to do this.
also check you dont need to fit a fuse in the fuse box too..
now if there isnt any terminals in the relay holder, you will have to wire it up, i think i have a diagram here somewhere, ill post one up soon, when i get the time to find it
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
i REALLY need to know how to do this for a VZ exc wagon. I have no copper terminals in the engine bay fuse box and no existing wiring :S
thanks
ok now ive stuffed that up a bit, what you will need to do is find the parker light circuit in the dash and connect it to the switch, parker circuit to one side, relay to switch on the other side, i havnt seen how the switch works as i havnt dealt with one before but the rest is how it will work
