Results 1 to 10 of 10
Thread: VZ Cold Starting Issue
    06 VZ Executive
    Nov 2008
    Unhappy VZ Cold Starting Issue
    Hi all,
    In the last few days I've noticed an issue with my VZ. For the "first start" of the day, it has trouble getting going. It will turn over significantly longer than normal before firing up.
    The "first start" today was different, however. It turned over, started, but was coughing and spluttering something shocking with the engine light still on so I turned it off, waited a minute, then started it and it was fine.
    I've done some reading of other issues people have posted here in the past with the VZ and starting, and have read things ranging from cleaning key heads through to replacing the battery, but none of their symptoms were quite the same as mine.
    Does any one have any ideas as to what could cause this?
    On a side note, a couple of times when I have arrived at my destination, put my car into park, pulled on the handbrake, a two-tone beep happens and something appears on the dash display just as I turn the car off (which then clears the message). I've never caught it quick enough to read it and I can't reproduce the problem, as its only happened two or three times. I think it might have had the word power in it somewhere but I'm not sure.
    My VZ is still under factory warranty until August next year, so perhaps I should just go straight to the holden dealer?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    the power thing would be powertrain fault with a picture of a engine and a lightning strike or something through it,
    how old is the battery? is it like a slow to turn over or it excessively winds over,
    id just take it to holden and get them to check it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    06 VZ Executive
    Nov 2008
    Quote Originally Posted by andyman View Post
    Hmm, powertrain fault. What does that mean?
    Not sure how old the battery is. I tried looking for a manufacture date (it was in it when I got it) but it wasn't on the top of the battery and I wasn't sure if I could rip it out without having to put the bloody pin number into the radio again, lol. I might rip it out anyway and have a look.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    if its the factory battery it wont have a date on it, factory batteries are plain black with a sticker across the top and has danger or warning written in red.
    it most likely is the factory battery.
    anyway, powertrain fault means an emissions related fault, service vehicle soon mean a non urgent code has been logged and will only flash when turning the igntion on and off, throttle control fault is as it means, fuel guage error is as it means.
    does the abs fault happen to flash up on the screen when you crank it of a morning?
    06 VZ Executive
    Nov 2008
    Hm, it's not a factory battery then. It's a Century battery IIRC (cbf walking out in the rain to check again). Definiately not black though. Yellow with a blue top.
    Emissions fault eh. I went into diagnostics (mode+set on startup) and there was nothing in the last error code part (but that might not be relevant anyway?).
    The ABS light has always illuminated whilst starting (which is normal?), but I've never got an ABS fault on the screen when cranking it either.
    Going to put the battery tester on it tomorrow morning, to see if there's signicant power drain overnight happening (hence the difficulty in starting), but I'm thinking it's probably something other than the battery which probably requires special attention by Holden. Also will be picking up a couple of rellies so I'll see if it does it again tomorrow morning.
    Also, would it be possible for a clogged fuel filter to cause this issue? Someone suggested to check that.
    Thanks for the feedback though peoples, muchly appreciated If I could give rep I would.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by boofis View Post
    hmm ok, fuel filter is a possibility, but it should also decrease performance once its running to, just let holden check it out,
    the abs fault which i was referring to, usually happens when there is a low voltage during cranking, sets a low voltage code but resets itself when running
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    sometimes when I put my car in park and put the handbrake on the beeps come up like yours does and on the screen it flashes brake on the screen very quickly, all it is the car thinking your still moving and you have put the handbrake up, no big issue.
    06 VZ Executive
    Nov 2008
    Ahhh ok
    Quote Originally Posted by vp_berlina View Post
    Hm. Maybe that's what it is. That thought did cross my mind, but I wasn't sure if it was meant to beep at you "driving" with the handbrake on.
    On a side note, the bloody thing started perfectly fine this morning - it didn't do anything silly.
    Damn gremlins in my car!!!
    Again, thanks for the info guys.
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    yeah i agree....my svz does that as well....and i have noticed the same thing "the car is thinking you r still movin and you've put the handbrake"....
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
LinkBacks (?)
  1. 09-02-2009, 03:13 PM
  1. Starting Issue
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 03:52 PM
  2. Starting Issue
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2008, 07:34 PM
  3. VT Commodore Starting issue
    By hitman1979 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2008, 10:00 AM
  4. Odd starting issue
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2007, 02:21 PM
  5. Starting Issue
    By Glover0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2006, 10:29 AM
