Results 1 to 6 of 6
Thread: Bushes
    2005 VZ ute
    Nov 2008
    Nowra
    Default Bushes
    I am going to change springs and struts over on front soonish and was wondering what bushes i should replace while its all removed?
    Tahnx
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    providing the strut top bearing dont fall apart when remove the top piece of the strut, you shouldnt have any issues, if it does any you get find all the balls, clean them up the the two shells and regrease them and put it back together, should be fine, if you loose balls like i did on mine - prick - they are $19 from holden
    there isnt terribly much to replace that operates off the strut in these, i.e ball joint sway bar links etc etc
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    the z bar and control arm bushes should still be good unless your car ahs done lots of K's ?
    2005 VZ ute
    Nov 2008
    Nowra
    greenacc's Avatar
    VE Berlina
    Jul 2008
    should be OK i'd say. I've been replacing my original bushes today on my vs , its done 240000, and the bushes could have lasted another few years. Depends on the performance you want tho. the rubber ones are soft and comfotable, but not that good for performance. Have a look at the bush on the fron tof the Z bar. If it looks torn or worn you could have a go at that one, they seem to be the first to go.
    2005 VZ ute
    Nov 2008
    Nowra
    ok Thanks for the help.
  1. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  2. bushes
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2008, 08:47 PM
  3. Rubber Bushes
    By holden007 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2006, 03:26 PM
  4. Z-Arm bushes
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 01:11 PM
  5. Z bar bushes or Radius Rod bushes?
    By Shounak in forum General
    Last Post: 12-04-2006, 05:29 PM
