Results 1 to 5 of 5
Thread: my lh rear makin noise
    VZ SS 5.7
    Jan 2009
    Angry my lh rear makin noise
    hi ppl
    i have a vz ss and its makin noise from the lh rear. about 2 months ago i kissed a kerb wen i was giving it abit of **** and have bent summin. i jacked the car up and had a look and the facia where the rotor sits on is bent can u replace that individial bit or do i need a whole new axel.
    please help
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    could you put a picture up, and ill give you an idea of what needs to be replaced
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY SS UTE A4
    Jan 2009
    Sounds like the wheel bearing but you will need special tools to replace it
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by ren11000 View Post
    i wouldnt make the assumption that, that is the problem
    VY SS UTE A4
    Jan 2009
    Neither would I. That would be foolish with out diagnosing it. Just suggesting it may be worth checking and pointing out that special tools will be required to replace it if that were the case
  1. makin a vs v6 go faster cheap
    By Hillam069 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2008, 09:40 PM
  2. Makin cakes
    By Sphinx in forum Jokes/Humour
    Last Post: 10-06-2008, 09:29 PM
  3. air con makin noise
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2006, 05:52 PM
  4. Makin da music LOUD
    By My Car Pwns in forum Car Audio
    Last Post: 09-03-2006, 01:36 PM
  5. VP stalling & fuel pump makin' a racket!
    By dalamar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2005, 09:41 PM
