Results 1 to 12 of 12
Thread: Suggestions Wanted - Crewman X6 VZ - want to improve towing
    Crewman X6 vZ
    Jan 2009
    Default Suggestions Wanted - Crewman X6 VZ - want to improve towing
    Just wondering if I can have a few suggestions to improve the towing on my Creman VZ X6. I did a lot of long distance this year towing 2000kg around (with a loaded ute) and the car went really quite well. I'd just like to improve it a bit for when I hit the country hills.
    I've rung around and got various options from centres quoting up to $10k for all sorts of work. It don't think i need to get that carried away.
    Any one out there got a suggestion or two?
    Travy's Avatar
    Travy is offline A bogan with style
    Hilux 4x4 Xtra Cab
    Feb 2008
    Crewman X6 vZ
    Jan 2009
    Handling is fine
    Power really. Cruises along very nicely on the flat at 90km with all that weight but slows right down on the hills.
    05 VZ Commodore Equipe
    May 2007
    Get a trans cooler if it’s an auto
    Maintenance wise:
    Change the diff fluid to a quality recommended synthetic.
    Use a decent XW40 or Xw50 oil as your oil temp will be much hotter and change it regularly.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    VZ AWD One Tonner
    Jul 2006
    You're in the same boat as me, except my One Tonner X6 is slightly lighter than the Crewman X6, and we tow about 2t with the rally car and trailer PLUS half a tonne in the tray. I wouldn't say it struggles, in fact quite the opposite, when we went to Melbourne this year for a rally we sat on WELL (and I mean WELL!) above 90km/hr. Is yours a VZ1 with the 4spd or VZ2 with the 5spd? I find in our 4spd (X6 OT didn't come in VZ2) that 90km/hr isn't high enough in 4th gear to be useable, so we tend to sit well above that to give the engine a change.
    As stupid as it sounds (and less stupid now that it's out of warranty) I've very much considered a supercharger, and it would probably both improve towing power, and improve towing fuel consumption. But if you've got the 5spd be weary...
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    id go for a vcm suite tune, other than that for more power f.i is the way to go
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    ya go a v8 turbo diesel, thatll tow the factory your car was built in.
    The Black Beauty
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    diff ratio change will help..
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by burnz View Post
    REALLY hard to do in the AWD's. V8 would be a waste of money when a supercharger for similar, if not less dollars will delivery the same results without re-wiring the entire car.
    danja's Avatar
    Jan 2006
    Quote Originally Posted by gslrallysport View Post
    If going V8 I'd just get a whole new car.
    The time/effort involved in the transplant, lower resale value (compared to factory V8) and the general low prices of gas guzzlers at the moment doesn't make an engine swap the most practical option.
  1. What should i do to improve my vy
    By nezzy88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-09-2008, 08:07 PM
  2. Would this improve performance at all?
    By Razor- in forum General
    Last Post: 10-08-2008, 02:10 PM
  3. front end suspension upgrade with limited funds... suggestions wanted...
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2007, 08:12 PM
  4. wat can i do to improve my performance in my VT ??
    By 07miana in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2007, 11:52 PM
  5. how to improve the handling of a vh
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-09-2005, 10:37 PM
