Results 1 to 23 of 23
Thread: V6 Owners With Strut Brace, PLEASE READ...
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Default V6 Owners With Strut Brace, PLEASE READ...
    I noticed today that the strut brace is rubbing again the A/C hose the runs from the compressor to the fire wall.
    Now im not sure if it would rub through the hose and make it leak as im sure its a steel braided hose, anyway its an expensive looking part so im sure no one here wants to replace it so on the off chance this is a little DIY i created to correct the problems.
    Requied Parts
    - 1inch diameter black plastic conduit
    - Metal strip
    - Black Electrical Tape
    Here is the problem:
    Solution to the problem
    1. Grab a thin piece of steel and bend it to the shape of the pipe, I used one of the clips that hold brake and speed sensor wires to the strut, just chopped the ends off and linished the corners smooth,
    2. Position the piece of metal to the right spot and tape it onto the A/C hose where it has been rubbing
    3. Stick the piece of conduit over the pipe and tape up the end to make it look nice and flash.
    I made this up out of part lying around my toolbox at home, you can substitute your own bits and pieces you have lying around instead
    So there it, if this helps you out, you know what to do, I like getting my rep points!
    Andrew
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Hi Andrew
    Good work - a lot of members might have installed the bar and not noticed the wear on the hose. I had a hose let go in my HZ years ago - the pressure in the hose on a really hot day is very high and a weak spot in the hose cause by wear would be the obvious spot to let go.
    Off post a bit - have you noticed any difference in the car's handling with the bar installed?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Just went & checked mine & it is starting to rub, not as bad a ur's Andrew
    Will attack mine 2moz, 2 drunk atm
    Thanx for the Heads up
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Calaber View Post
    Hi Andrew
    not terribly much around town, but tight twisites in a mountain seems to roll a wee bit less
    VZ Wagon
    Jul 2005
    Thanks mate, just installed the strut bar today and hadnt noticed that. I just went and checked and it is definatly rubbing! Will sort something out though with the help of your observation
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Seems like you saved a few burst hoses here Andyman. Just wondering if you could just grind a few mm off the corner of the Strut bar instead to stop it rubbing ? doubt it would weaken the bar at all.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I'll check mine tomorrow... hopefully it is alright, the strut brace has been on there for about 3 years
    Sep 2006
    Good post, identified a common problem. Is there anyway that the pipe can be angled down? If you went to an A/C shop could you get them to angle the pipe down or is it permanent in that position?
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    I had a look at this area of my VY Ecotech. The problem probably won't arise with VY's because the hose design is completely different. The receiver/dryer is located just to the left of the strut tower and the hose is lower than the VZ.
    About the only thing I can see that might cause an issue is the accelerator cable assemebly.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Great job Andy - I'm getting a brace for mine soon, so now I can be sure the problem won't crop up!
    All the best for the NY to you Mate....
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    another option is to grind the corner off...
    ive removed my strut bar when the charger went on and cant say i notice and difference with it gone...
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by greenacc View Post
    Quote Originally Posted by SSbeast View Post
    yes and yes to both,
    although by accident when i was playing around it, the aluminium pipe where the hose meets the compressor bends real easy i found, this also made it clear it by about 3mm - not much though and runs the risk of fracturing a pipe,
    grinding the end of the strut bar off sounds like the perfect fix, might do that and get rid of the conduit and give it that factory look again
    VZ SV6
    Aug 2008
    Default Mk II version
    After reading the Thread from Andyman (good onya for spotting that one!!!) i had a look into it and added the following so that the rubbing woudnt occur and ensuring the aircon hose can still be replaced if needs be and no need to add anything to that hose.
    all i used was a the folowing;
    a hose clamp- to go around the strut brace
    a U-shaped bracket can be L shaped to but this was available
    and a clipsal pvc pipe bracket where the hose is cradled in
    took me like 1/2hr to do and that including hitting it with a coat of black.
    the pics are self explaining.
    the MkII bracket will ensure a more rigid fitting cradle for the aircon hose to lay in. incase of any vibration the hose will just move in the bracket and no sharp edges.to wear against.
    sorry for any blurred fotos but took it inside workshop
    Attached Thumbnails Attached Thumbnails V6 Owners With Strut Brace, PLEASE READ...-10012009.jpg   V6 Owners With Strut Brace, PLEASE READ...-10012009-001-.jpg
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    lol good one, love the 'mk11'
    cheers
  16. #16
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
  17. #17
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    Had a look at mine, there's about 1mm clearance between the pipe and strut brace, and there is no evidence of rubbing between the brace and pipe. Having said that its something I'll be keeping an eye on
  18. #18
    EQUIPED is offline AM VZ
    VZ Equipe 2005
    Sep 2007
    quick question regarding the 2 hole mod - what happens to the open MAF end of the pipe after the mod?
    VZ SV6
    Aug 2008
    you replied in the wrong thread dude.
    Quote Originally Posted by anuraagmohan View Post
    jet-6's Avatar
    jet-6 is offline Yer im that guy!
    MY06 VZ SX6 ADVENTRA
    Oct 2008
    East Gippsland, VIC
    Checked my car today, factory fitted brace, and the air con piping is quite different, its way down on the rail and miles away from anything
  21. #21
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by jet-6 View Post
    adventra, while looking like a commodore wagon has a very much different body, and alot of systems or way its built is very different
  22. #22
    ucrvme's Avatar
    ucrvme is offline [UCRVME]
    2003 Holden VY Berlina
    Mar 2009
    Melbourne, Victoria
    Thanks for the advice! i didnt have any spare little pieces of metal but i had some braided hose sleave left over and reinforced it working great thanks.
  23. #23
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Has anyone thought of just bending the pipe down a little so there is no contact with the bar I did there's no need for all this. It's all the Holden dealerships do as well.
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
  1. Strut Brace
    By 89 vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2008, 11:04 PM
  2. strut brace
    By adamc11 in forum General
    Last Post: 20-02-2008, 08:05 PM
  3. Strut Brace
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2006, 09:05 PM
  4. strut brace
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2005, 11:24 AM
  5. Strut Brace
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 12:54 AM
