Results 1 to 8 of 8
Thread: "Check Powertrain "
    vz berlina
    Jan 2009
    Angry "Check Powertrain "
    Hi Guys
    Last week i purchased an '05 VZ Berlina when i purchsed the car the check powertrain message was displaying on the dash. The dealer told me this was just the sensors ans is a common but easily fixed problem.
    So off the car went to have the O2 sensors replaced , got it back and started it for the first time and once again the same message, had to leave the car there overnight for the problem to be fixed.
    Went there to pick it up the next day, started and the screen said system check OK! All good you would think... about 15km later "check powertrain" flashes on the screen again.
    Back to holdens we go, replaced the sensors yet again, same probelm, off to a different holden dealership to have the software updated and the "module" replaced. all good until about 5kms down the road... Same message "check powertrain".....
    Does anyone know how to fix this problem for good? I would apreciate any feedback!
    Thanks
    gdunkley84's Avatar
    gdunkley84 is offline I Have a Dent.
    2005 VZ SV6 6SPD (HBD)
    Jan 2005
    Hammond Park, WA, 6164
    Get them to check the wiring to the sensors, make sure they are not touching something hot where they shouldn't be.
    2005 VZ SV6 6SPD - Holden By Design
    MY06 VZ SV6 A5
    Jan 2011
    Campbelltown, NSW
    Quote Originally Posted by vz2822 View Post
    Hi Guys
    Thanks
    Hey mate, how did you go with this check powertrain warning light? Have you got it fixed? If yes please tell us what the problem was as Im currently having similar problems with my VZ SV6 and currently having a big s**tfight with Holden trying to get them to fix the problem.
    VZ Thunder S 6spd
    Jan 2011
    Dromana Vic
    hey buddy dont know if u have had it fixed but had the same problem. the warning message showed up and turned my car off. turned out it was the thermostat sticking causing other probloems and this problem.
    OZTEEL
    vz wagon
    Aug 2006
    Wild west of Melb
    Get them to scan it as mine comes up and it is the timing chains had the dik
    VZ Commodore Ute
    Oct 2010
    Mine was the No.2 Coil pack
    had it replaced and been going like a champ
    although mine did show a misfire error (3000 & 3002) from memory
    so Id say get a data scan to save the guess work
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    my mates vz acclaim does this.. everytime he turns the car on it beeps 'powertrain' , he presses mode and it goes away till he turns the car on again.
    also on an unrelated but could be linked from what ozteel said.. hes loosing coolant and we cant see where from??
    MY06 VZ SV6 A5
    Jan 2011
    Campbelltown, NSW
    Quote Originally Posted by ozteel View Post
    2 Holden Dealerships had scanned my car and came up with "bank 1 o2 sensor' fault. Both has failed to fix the friggin problem after both pre-cat o2 sensors were replaced. Took the car to an independent workshop who is an auto electrician aswell, their scan tool came up with the same friggin code. Next check is the ECU but I pretty much doubt it that it is the ECU I mean come on the car is only 4 1/2 years old.
    Commodore is a great car but this s***ty electrical problems and their service centres' incompetence to diagnose and fix the problem is a big let down and I doubt I will fork out my hard-earned dollars on another Commodore
LinkBacks (?)
  1. 22-04-2011, 06:31 PM
  2. 09-04-2011, 09:00 PM
  3. 13-03-2011, 10:56 AM
  1. "check cd error"
    By richardvy6699 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2009, 11:05 PM
  2. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  3. "Check Oil" Alert Message
    By VicCop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2007, 10:20 PM
  4. VT series 1 door "check strap"
    By cliffo78 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2007, 11:37 AM
  5. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
