Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: rear speakers
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    Default rear speakers
    ok guys ,is their wiring hidden somewhere 4 speakers in the parcel shelf of a sv6,their is a place 4 speakers but i carnt see any wires
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    You need to run the wires. They can be found beside your drivers seat under the plastic trim. You get both left and right hand from there.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    I might run a set of speakers in the parcel shelf then
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    SV6
    Aug 2008
    LISMORE NSW
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Personally I wouldn't bother. Good speakers in the rear doors and good splits up front + sub is better than spilts 6x9's and sub anyday. Reason being that you want the sub to handle all the bass, and having 6x9's just makes too much bass and not enough midrange in the cabin. Mate of mine is a pro car audio installer, HIGHLY recommends previously mentioned setup as the way to go, been in the industry 10+ years. But that's his opinion, it's what I have gone with, and having had both setups in the past, is better by far.
    Me? I'm the guy who does his job ... you must be the other guy ...
    Nov 2005
    Warrnambool
    Quote Originally Posted by Ewok View Post
    That may suit you, but i don't want all the doof doof out of my music that a sub delivers so i'll stick to the 6x9s.
    VZ SV6
    Dec 2006
    I have an SV6 with standard 6*9's in the parcel shelf, looking at ungrading the speakers at some stage. Is there wires in the rear doors to take speakers or do they need to be put in?? Also i don't know very much about audio setup but if i was to replace the 6*9's with better ones does that mean the wiring needs to be replaced to handle extra power??
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    No wiring does not need to be changed to handle extra power at all. The only thing you need to worry about is are you going to be happy with the sound coming from the deck or do you want to boost the sound and run it from an amplifier? You can go all otu and buy really expensive audio-kits for wiring like oxygen free (wank) wiring kits and gold plated / full copper strand RCA wiring kits aswel, which you'd be looking at about $150+ per kit, but unless you are one of the I think it's something like 1 or 2% that have perfect hearing and can tell the difference? Not worth it. Just make sure that where the sound is being produced from (deck/amp) has enough power to utilize the full potential of the speakers otherwise they tend to distort at a low volume (good way to tell if not enough power to em )
    Hope it helps some.
    -Chris
    VZ SV6
    Dec 2006
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    That should do it yeah Unless the speakers you are putting in require more peak power, in which you might (if you are running them off the deck) want to install an amplifier, but if you are already using one, then you should be fine
    evil-matty's Avatar
    evil-matty is offline tyre smoke is normal
    5.7V8 VZ SS M6
    Jan 2009
    Hamilton NZ
    Hey JUZO, do you mean there are spare left and right wires by the seat that are there to be extended for 6 x 9's or do you steal the ones to the back doors?
    I'd be quite happy with some 6 x 9's, dont know why they arent standard these days...
    SV6
    Aug 2008
    LISMORE NSW
    cma r your rear speakers standed or has someone put them in,if they came standed then, i got the povity pack
    VZ SV6
    Dec 2006
    Quote Originally Posted by skyper View Post
    they came standard mate, well actually factory option - premium sound upgrade - meaning 6*9's in parcel shelf and 6 disc in dash cd player
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by evil-matty View Post
    bump keen to no so i can do it today
  15. #15
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    thats the way a sound system should be set up in my opinion..all bass running thru the subs and the music thru the speaker, and splits up front would be mint haha..plus having 6x9's in the parcel shelf can get stuffed pretty easily due to being in the sun all the time i have been told
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
  16. #16
    vr equipe
    Jan 2008
    when changning from factory speakers to aftermarket you will need to get a stubby screwdirver to undo the speaker as the back screws are very close the the window you will then have to cut off the harness that clicks into the stock speaker and figuire out wich wire is posotive and negative then connect t new speaker and screw back in it is pretyt simple
  17. #17
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
  18. #18
    Nov 2005
    Warrnambool
    If you want 6 x 9's you need to disconnect the rear door speakers and use the wires for them on the 6 x 9's. Hope that helps you archer.
  19. #19
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by Archers View Post
    anyone? ...
    Hi Archers
    If you are wondering whether the wiring is in the car for rear door and rear parcel shelf speakers, the answer is no. The wiring is run as standard from the dashboard down the front pillars and into both front doors, on all models. The wiring continues along the door sills to a connecting point at the foot of the centre pillars in all models (excep, I think utilities but could be wrong).
    From there the wiring is fitted accoring to the level of trim and equipment fitted. Base models up to and including Berlina have rear door speakers standard, so the wiring harness is fitted from the connector mentioned above, to each rear door. Calais and upward had the four door speakers plus rear shelf speakers, with amp and various other trinkets if you have a Statesman or Caprice, so their wiring looms would run to the rear doors and the rear shelf.
    There is no standard pre-fitted wiring for rear shelf speakers in the models below Calais.
  20. #20
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    great guys thats what i needed to know i will just make the 6x9s slaves to the back door speakers thanxs scott
  21. #21
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
  22. #22
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    Personally I wouldn't bother. Good speakers in the rear doors and good splits up front + sub is better than spilts 6x9's and sub anyday. Reason being that you want the sub to handle all the bass, and having 6x9's just makes too much bass and not enough midrange in the cabin. ..... it's what I have gone with, and having had both setups in the past, is better by far.
    This 100% i say.
    Ewok have you always had a GTR?
  23. #23
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    so if i want to put 2 6 by 9s in the parcel shelf, do i need to pull out the deck n rewire? or is the wiring found somewhere else?
  24. #24
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Henry
    Read my post above. You have an Exec, so your standard wiring will be for four dour mounted speakers ONLY.
    If you want rear shelf speakers, you will have to put in the wiring from the centre pillars back to the shelf yourself.
  25. #25
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    just finish puttin in the rear speakers works great just on the vz exec i can say that the wire wasnt there at the pillar, i just hooked it up to the rear loom for the speakers to work sounds alot better,
  1. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  2. rear speakers
    By ad45 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2008, 05:22 PM
  3. VY UTE rear speakers?
    By mawsy in forum Electrical Wiring / Questions
    Last Post: 19-05-2008, 02:43 PM
  4. GTO rear speakers
    By myhsv in forum Car Audio
    Last Post: 13-07-2006, 06:09 PM
  5. vs rear speakers
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2006, 07:40 PM
