Results 1 to 7 of 7
Thread: vz 05 wagon wont start
    VZ Executive 05 WAGON
    Jan 2009
    Default vz 05 wagon wont start
    my vz wagon wont start(its in park) its got very low fuel, fuel gauge error and service vehicle soon warnings coming up on the dash, has heaps of fuel in it. could this be a relay or fuses problem.
    vz executive
    Jan 2009
    change your fuel filter as a first cheap option. there is a howto in this forum.
    Jan 2009
    Quote Originally Posted by shakey View Post
    thanks my mechanic seen to think its the abs computer playing up, he disconnent the abs unit on other vz and the same faults come up after all the faults where re-set l keep u posted.
    vz executive
    Jan 2009
    Reason i say fuel filter. Occasionally my car would start then die, start it again no problem. Then the other day crank nothing, crank nothing after about 6 times all the other warning lights came on. Had less than 10L of fuel, i put 20L in so now had roughly 30(see i can add up).
    Anyway this time it was cranking better, longer but still not turning over. Changed fuel filter and she started perfect. The little bit of fuel in the filter was literally like mud.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    thats allright, my car was started to gradually idle rougher, pulled the filter out and water was in it, new filter, good for a week, started getting worse, but now its getting better again, so im guessing it was just getting flushed through the lines lol
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vz executive
    Jan 2009
    Funny you say that andyman, That night after i changed it i was getting flat spot on take off and little bit rough idle now better. Im tempted to run this filter for say 2 to3 thousand kms, then change it. Pays to fill up before it gets to the redline.
    Jan 2009
    seem the problem was a internal fault with the pim and ecu they were replaced we see how it go's
  1. Vp V8 Wont Start
    By rod baker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2008, 09:08 PM
  2. 5 spd 91 VN wagon cranks & wont start
    By lldeanll in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-09-2007, 11:52 PM
  3. vc - wont start
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 04:35 PM
  4. VS Wagon wont start when hot
    By sholly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 12:42 PM
