Hi guys,
Im the new owner of an 04 VZ acclaim and am wondering if someone can tell me whether the panel next to the gear selector that shows whether your in drive, reverse etc should light up?
I noticed last night that mine wasnt lighting up so would i be right to assume there would be a bulb that needs replacing or does this panel not light up because it shows what gear your selecting up on the dash?
it should light up, in saying that i cant say ive noticed.... check your fuses and light globes,
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
had same prob definalyl lights up just take your consol apart n replace bulb
2000 VX Calais L67 !!!
When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
1DVSBSTD
I also have the same problem....
yeh it does light up coz Phreddy changed mine to an icy blue colour![]()
Drop the fuse panel and you will see 2 phillips head screws that attach the right hand console cover. The rear section clips in near the hand brake lever. Remove this panel and you'll see the light socket up there.
Phil
