Results 1 to 6 of 6
Thread: Check Powertrain warning message
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Default Check Powertrain warning message
    Just wondering if anyone knows exactly how to change the two oxygen sensors in the exhaust. My auto elec mate did a diagnostic after i got a check powertrain message on start. It does come and go the warning message. He said i need to replace the oxygens sensors in the exhaust. Im thinking that there their to check the fuel mixture ratio and adjust accordingly. And my fuel consumption has risen a little bit. Would that be because the oxygen sensors arnt working properly????
    VZ Berlina 2005
    Jan 2007
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by luke0011 View Post
    has anyone changed an oxygen sensor in a vz?????
    just unplug and undo with a spanner, they can be pretty tight to come out as some have a thread locker on them
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Exec
    Feb 2009
    yer ive got the exact same problem so all i need to do is replace the oxy sensors?
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    dunno how much price wise for new o2's but i know that orig part replacement itself is easy, 22mm spanna and plug n play, but trouble codes are static tho - that said i have and can happily provide the solution to fix that bit, not to mention varify function of the newies is no hassle.
  1. 2004 SV6 - 'Check Powertrain' caution
    By gam in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2012, 03:29 PM
  2. Check Powertrain- What the dealio?
    By EvoVIIIJDM in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-04-2009, 10:52 AM
  3. Check powertrain - engine cutting out
    By Uldis Esots in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-12-2008, 09:01 AM
  4. VT Powertrain Warning
    By DarkZarai in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 08:53 PM
  5. Check PowerTrain
    By bigboy_cad in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2008, 08:42 PM
