2005 holden crewman oct build checked fuse ,all good fuses.
anyone got any ideas
Either the wire at the back has come loose or the element has failed.
The Blue One
if you can, take the socket out, check continuity with a multimeter and use a test light to check power at connection
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
why not remove thecentre console trim on driver side footwell and under the radio you will see a 3 pin white connector ( the connector was used for smokers pack and like earlier models was a outlet for in the front there) 1 pin is the negative then the other one is 12v for lights when parkers are on and then you got 12v ideal for GPS etc etc
i wired my GPS into the negative and that 12v and then 2 small green fluros in each footwell using the 12v for lights and the (common) negative.hope this help
I Agree take it apart and check it out, Do you have the power plug in the center console?
yes cig socket in console .im lost without my gps.hope 1 of our utee guys can repair for me.will let you know how we go .thank you guys
yea got it working,was loose wire conection .
thanks guys
