ay fellas just a few questions, about my v6 vz 175
will a vt/vx diff fit a vz?
has anyone fitted a larger throttle body to a vz? does it have the same kick a vx does? or just a waste? can u swap the 190 manifold over to the 175? or to much work?
thanxs scott
are u talking about the intake manifold? because i think the 190 and the 175's are the same. As for the diff, i think you just need to change the tailshaft because the vz's are different to the vt/vx. not 100% but just what i have been told.
alloytec throttle body is already 70mm mate. no you can't fit the variable intake manifold to the 175kw motor. as for the diff no idea.
monaro is right, ^^^ the diff you can use one, you need to either change the tail shaft or change the bolt up flange that suit unis to the rubber uni flange, fyi keeping the rubber unis would be a better option
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Also, wats the ratio of the vt/vx diff! Is it higher than the VZ?
The Blue One
The Blue One
is there any point putting diff gears in? as i dont have a lsd? was gonna go 3.46
what a happened to not modding this one? lol. I think the VZ has 2.9's or somthing crap like that in em. even 3.45's would be a good up grade to get some low down tourqe.
would be much better with an LSD mate.
4sp auto has 3.08 and the 5 speed auto and 6 speed manual has 2.87 or there abouts
Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
