Hi all.
would an ss sedan rear bar fit a wagon? (if not how come)
if i were to fit a set of vz clubsport springs to my wagon would i need to change the shocks? or anything else for that matter? (im assuming the clubsport springs are similar to fe2)...
thanks guys![]()
By saying the rear bar u mean the bumber bar! If thats the case, no they would not fit, both bars are two totally different shapes. If thats wat u where on about!
Its usually best that u change the shocks when u do the springs, cause once u fit lowered springs, ur shocks will bottom out.
From wat i know sedan & wagons springs are different, so no, more than likely the springs out of vz clubsport wont fit the wagon.
The Blue One
The shock won't bottom out, the car will hit the bump stops before that happens, regardless of which springs you have. You do need to fit shorter shocks though just to trap the springs but. Wagon springs are a bit shorter than sedan ones but they have a different spring rate. People have fitted them, but I don't know how they ride.
The Blue One
im running the wagon SL HD's with the factory air shocks, (monroe gt sport in the front)
the ride is pretty good but if no air is in the shocks theres about 20mm of compresion room before it hits the stops, <makes terrible thuds when it does, so i have to run approx 200kpa of air to stop hitting stops, although in doing this is higher speed corners can make the back end feel floaty,
i think i might chop a little off the stop and see how it goes
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Correct me if I am wrong, I think the ute and wagon rear springs are the same in the VZ, rather than the sedan and wagon rear springs. I believe vz 6 cylinder front springs are interchangeable, but the v8's have a different front spring weight/rate.
I am looking at putting lowered springs in my wagon, nothing crazy, was thinking of 1.5 inch low springs, the next step down from standard, any suggestions?
The rear bumper definitly wont fit though.
cheers for all your help guys
