Greetings All,
I was wondering if someone knows the trade name for the fittings that lock into the cargo rail in the back of the VZ. I know that it is an aircraft style fitting and I've previously found the name of them and a supplier but do you think I can find it again.
I'm wanting to custom make some drawers for the back of the wagon so I'm after some stud type fittings so that I can bolt the drawers down.
Thanks, cc&c.
Try nvu.com.au - their "interior" section. Or direct from Holden - I paid $55 in a nice little pouch.
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Thanks for the replys. I have the tie downs in the little pouch and yes a bolt could be fitted down the opening. I have seen the exact item that I'm after but I just can't find it again. I found the rails and tie downs on nvu.com.au but it is the same tie-downs that I already have. Thanks again, I'll no doubt find what I'm looking for just I've installed another solution. Cheers, cc&c.
By the way, does nvu.com.au sell to the public or just people in the trade? I couldn't find any info on their website.
Apology for answering my own thread, but in order to assist others who may be looking for the same thing, I finally found what I was looking for:
The rail is known as "L-Track" and the stud fittings that I was looking for can be found here: Sure-Lok Products
Cheers, cc&c.
Just go down to your local ARB 4wd store, there floor tgracking system is the same and the clips are better than Holdens and only $9 a pair
The aircraft fittings that you are talking about are called 'Ancra' fittings.
See here
Ancra International Aircraft Fittings - Cargo Restraint, Cargo Control, Aircraft Restraint, Tiedowns, Strap Assemblies, Winches, Load retainers, Load bars, Tie Downs, Load lock bar, Load straps, Lashings, Securement, Cargo handling, Dock systems, Sho
Also have a look at the bottom of the page here
http://www.ancranz.co.nz/products/track.php
Anyone found a seller of "ancra" type products in OZ?
