has anyone looked into getting a larger intake pipe? [from the throttle body to the airbox?] just looking at ways to get a better low down power!!!
the cars got great mid but is so bad low down.
Ive been thinking about that 2.
On a closer inspection the throttle body inlet hole is smaller than the Airbox hole, so therefore you'll need a bigger throttle body, unless there is another way.
The Blue One
get a rubber clamp, i did a 100mm pipe on my vx and made a big difference in take of and bottom end. will a gen 3 fit? same box correct? and throttle is in the same location?
this is what i put on my vx but in black and 4 inch
http://cgi.ebay.com.au/AIR-INTAKE-HO...1%7C240%3A1318
gen3 runs a cable throttle not a fly by wire
Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
The Blue One
yea i remembered that after i posted but i was too lazy to edit lol
Hey All,
i wonder if our LS based intake pipe would fit if cut shorter???
I might try one this on the weekend,
Any one know the size of factory intake??
Micky.D
YT
Hey rvx 219,
They go for about $180, but may be cheaper if i get them to fit,
i didnt get a chance on the weekend but will try this week.
Micky.D
YT
Probably the best thing you can do for lowdown power with the VZ/Alloytech motor's is get VCM suite tune. Removes torque management so you dont have to be at 3500rpm for torque to be unleashed fully. Looking at about $900
Me? I'm the guy who does his job ... you must be the other guy ...
Read somewhere a while ago that they make performance intake manifolds for alloytecs giving a increase of up to 20hp
With the extra flow that should give heaps more bottom end.....combine with a tune on top of that then in can only get better.
Just thought it might be more gains and better money spent doing the manifold then playing with the intake pipe.
You talking about an OTRCAI jobbie? Coz if so as far as I am aware they don't make em for the alloytechs yet.
They do have otrs check the ve section a few are running them on their sv6's
They aren't a mafless otr
Ah that'd be why then. Still no MAFless tune available for Alloytech motors.
the alloytec performance manifold AKA CPR6, can be shipped anywhere in australia for 3300.... bit pricey i reken for only 20-30hp
