Results 1 to 24 of 24
Thread: squeaking idler pulleys
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Default squeaking idler pulleys
    Hey Guys
    Found my idler pulleys are starting to squeak a lot until the car gets hot, its a 6 litre, has anyone had the same problem ?
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    i have the same problem on my 5.7 litre.
    its not the idle tensioner but one of the other two idler pullies.
    Sep 2008
    I thought it may be that, haven't pulled it apart yet to have a good look. Sprayed some CRC on it and it went away for about 10 minutes and its back again. Its annoying
    Nov 2003
    Warrnambool
    sounds like mine.
    give it a spray and itll stop for a bit but it always comes back.
    seems to almost stop when the car warms up as well.
    im not sure if its a serviceable part or not or if its just one of those parts that your better off replacing and not worrying about it.
    would like to hear other peoples thoughts though.
    Supercharged VU SS
    Feb 2006
    The Shire
    sure its not the belt, my sv6 would squeak sometimes when cold, or if it was wet(had bonnet scoops) changed the belt and the problem never came back
    same deal with a mates monaro, was making a similar noise to my sv6, changed the belt for him and problem solved
    VT
    Apr 2005
    QLD
    Theoretically, if the pulley is plastic, it will be expanding faster than the captive bearing inside, this will increase the clearance between the ID of the pulley and the OD of the bearing. There may be some movement.
    But i could be wrong too, whilst talking out of my arse.
    Nov 2003
    Warrnambool
    i know mine isnt the belt.
    if i spray behind the pulley (or around the bolt) it shuts up for a bit.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    replace the pulley thats squeaking, simple, if you spray lubricant on the pulley make sure its not getting on the belt aswell
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VX acclaim wagon S1
    Feb 2008
    sydney
    yeah i work on a few 6L and ive heard plenty squeaking, also heard the radiator fans sqeauk a bit too, usually most have had roughly ~100,000 klm
    Nov 2003
    Warrnambool
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Its either the Pulley or the Bearings inside the pulley.
    Not sure of the cost, i just tightened up the idler pulley & the noise went away but this was on a different car.
    No squeaks on the SV6 as yet!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VT COMMODORE
    Dec 2008
    Is the idler the part behind the pulley? Mine gives an occaisional movement every couple of seconds. There looks like there is a spring inside? How can this be fixed?
    evil-matty's Avatar
    evil-matty is offline tyre smoke is normal
    5.7V8 VZ SS M6
    Jan 2009
    Hamilton NZ
    I have same annoying squeal. Lasts about 5 minutes until engine is warm then is practically gone. Tried explaining to mechanic but would have to leave car overnight for them to cold start it. They lubed some pulleys and it was gone for about 2 weeks but back again. car has only done 35k so not like its old and worn? anyone know if its a cheap or easy fix? VZ SS
    Supercharged VU SS
    Feb 2006
    The Shire
    ok found another example to back up my belt theory.
    today the boss' vz monaro had the belt changed to stop the squeek.
    so that 3 cars i know of, all fixed by replacing the belt, it cost about $25 bucks and takes 15 mins to change,
  15. #15
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Quote Originally Posted by black as View Post
    Use Innox spray, or lannox. They are some of the best spray lubricants. Just dont get it on the belt. See how they go. Its like a common thing with Holdens.
  16. #16
    VZ
    Feb 2007
  17. #17
    VZ executive
    Feb 2009
    i have the same thing! i change the belt over and in about 6 week's it come back. but it only happen's when the car changes gear, it's got some think to do with the rpms of the motor, i think
  18. #18
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by richie_rich View Post
    inertia of the water pump still trying to spin faster, happens at high rpm
  19. #19
    Sep 2008
    Quote Originally Posted by andyman View Post
    I don't think its that because it does it at idle until its warmed up a little, tried CRC and talc powder and its still there
  20. #20
    VZ
    Feb 2007
    my car is at the mechanics rite now getting new bearings in them..ill let you know how it sounds when i get it back
  21. #21
    Sep 2008
    Quote Originally Posted by HUMBLZ View Post
    Cool......thanks mate
  22. #22
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    could also be an alignment issue with power steer pump i think, mine was squealing when i bought it, but i just got it fixed under warrenty
  23. #23
    VZ
    Feb 2007
    noises all gone after having the two idler bearings replaced..back to normal finally no more listening to stupid noises in traffic
  24. #24
    Sep 2008
    Thanks mate, replaced mine last night and its all good
  1. VX V6 Idler pulleys / Drive belt
    By glenward in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2008, 07:25 PM
  2. VS V6 Pulleys
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 07:53 PM
  3. Need help removing pulleys
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2006, 04:03 PM
  4. VS V6 Engine Pulleys
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2006, 09:57 PM
