Results 1 to 22 of 22
Thread: VZ SV6 problems!
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    Default VZ SV6 problems!
    OK so i just picked up a Dec '05 VZ SV6 auto. A couple of thing ive noticed are when braking the stereo seems to get quiter and when accelerating, gets louder. Also, when the head lights are set on auto, they wont turn themself off, so for now i have to just use them manualy. Any ideas? are these common problems?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    im not sure about your lights man, but the stero is competly normal my dads sv6 does the same thing, its too compensate for the noise of the road and engine noise, so more u accelerate the louder the stero goes and when slowing down goes quite ect
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VZ SV6
    Jul 2008
    Wogboyz is spot on with the stereo, you can turn the feature off when you run through the options as you start the car and press "menu".
    Not sure about the lights either though, mate
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    any more details on the stereo? i went through the menu and had nothing about the stereo in there. Did show me how to reset the trip meter though, thanks for that too haha.
    Also, can anyone comfirm if the dec '05 have the factory LSD or not? that thread about it seems to be mostly heersay and no real answers.
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Quote Originally Posted by GTRwilson View Post
    Sh*t I just took my VZ back to Holden this morning as I have been having drama's with my radio & headlight switch. (Both probs same as yours)
    Radio: This looks like my bad as the boys have mentioned above there is a on/off switch in the mode set up all to do with road noise volume.
    Headlight Switch: Holden found some bare wires, where a tow bar has been fitted. Hopefully this has fixed my problem.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The volume on the car is speed dependant, in other words the faster u go the louder it gets. The slower you go the quieter it gets. This setting is accessed by pressing the volume button & cycling through until reaching the desired setting.
    With ur headlights, its most likely the sensitivity setting (low-med-high).
    Depending on what setting u have it on, this will determine if ur headlights stay on in the day or not in the auto setting.
    If you have it on high, on a overcast day this will cause the lights to come on.
    If on medium, usually between dawn till dusk, you'll lights will stay off
    If you have it on low, the lights wont come on until its reasonably dark.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    Quote Originally Posted by Rovert View Post
    What was the cost for them to look into this? Mine has no tow bar, so could be something else.
    Quote Originally Posted by PaulSV6 View Post
    i understand how the auto setting works, but shouldnt they turn off when i turn the car off, lock it and walk away?
    Feb 2005
    St Clair
    ALL FOR FREE Under Warranty.
    My same as yours not turning off, even after 10 minutes my headlights stayed on..
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    There is a approach & delay (off) time setting, this is accessed through ur trip computer.
    Turn ur ignition on, hold mode & set Wait for the system check & the options menu will come up, press up or down button to continue & then press mode each time to access the different settings.
    Ive got mine set to 30 seconds approach & off.
    The Blue One
    Quoted for truth
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    im assuming the cd player is turning off aswell, when the drivers door is opened?
    as just mentioned, check the approach and departure time setting, they may be set for 2 minutes or so, change it back to say 20-30secs and see if that works
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    I tried going through the menu setting. Had things like stopwatch, average fuel use ect ect. is this the right menu settings? because there was nothing about the headlights or any timing settings.
    also, i went through the setting for the CD player, and only had like trebble, bass ect.
    Quote Originally Posted by andyman View Post
    yes CD player turns off when drivers door opens. As above, cant find settings
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    when you turn the key to 'on' and system check appears, after that finishes, it will say, press ^ and v to enter options menu,
    press either up or down when that is on the screen and use the mode button to change between the options
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    OK got it thanks.
    Whats the best way to find out if any warranties are still current? Can any Holden dealer tell me?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    OK got it thanks.
    If the vehicle is 3 yrs or more old or has travelled in excess of 100,000 km's then unless there was an extended warranty offered to the previous owner that was transferrable to you, then you will be out of luck. When you purchased the car 2nd hand it should have had a statuatory warranty - probably at least 3 months (depending on requirements for your State).
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    OK got it thanks.
    3 years from the date of first registration, or holden will tell you
  16. #16
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by Benboy View Post
    even then it depends on what that warranty covers, i know the extended warranty i have with mine only covers the ecu under if its electrical, not too sure on what mech stuff it covers.
    Chev badges are an instant fail
  17. #17
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    OK well i wasnt told about any existing extended warranties so im guessing there are none. Any way of finding this out?
    Also i thought i fixed my stereo problem, but apparently not. The only audio related option was about max volume or to do with distortion or something...
    But i did manage to fix my headlights, and that annoying auto door lock!
    thanks for this guys!
  18. #18
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    the stereo one is called 'speed dependent volume' i think, turn this to 'off'
  19. #19
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
  20. #20
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ill check again, but i swear there is nothing even remotly like that.
    it'll be there, it'll have road speed dependent volume, or speed dependent volume
  21. #21
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    just checked again, and deffinantly no option like that. Might stop in at Holden tomorrow and see what they say.
  22. #22
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    ALL FIXED NOW! turned out to be none of the things mentioned above.
    called Holden and they told me where to find the exact details in my owners manual. Had to start car, then thurn stereo OFF. Then hold ON and '1' at the same time until it went in the Options. Then turn it off via that.
    Thanks for you help with everything people.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. fan problems
    By Black.Label in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2008, 06:06 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. car problems
    By quick308 in forum General
    Last Post: 07-08-2006, 05:54 PM
  5. Any Problems
    By andyman in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-05-2005, 11:16 PM
