Hi Guys
I have a strange screaching noise coming form the front when the steering wheel is turned either right or left slightly(around 30 degrees either side). I am taking it to holden maybe this weekend, but just any thoughts what might be wrong?
thanks
Ride: VZ SVZ
MODS: Darkest legal window tint
3 inch catback exhaust
Genuine Holden front strut brace
Xenon blue headlamps & number plate lights
CAI with POD setup
NEXT:
upgrade music system
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Did by any chance have new front brake pads installed, cause if whoeva did them forgot to remove the backing plate this can result in the noise.
The Blue One
no paul didn't have the pads but will be getting the discs machined pretty soon as there is a lot of steering shudder when braking...
my mechanic checked the oil level (i didn't actually have a look) but will look in the evening when i get back from work...will update you....
Ride: VZ SVZ
CAI with POD setup
NEXT:
just checked the power steering oil level it is on the min level for cold....the car was sitting in the garage since yesterday...is it normal or should it be more????
Ride: VZ SVZ
CAI with POD setup
NEXT:
little more for cold but maybe check the belt tension as this may cause your screaching under load if you have rims fitted?
Ride: VZ SVZ
CAI with POD setup
NEXT:
I would be highly suspecting the drive belt tension is on the low side. The large amount of extra power required for the power steering pump when on full lock would be more than enough to cause an horrendous squeal from the belt slipping. Specially if you've got wider tyres on.
Took the car to holden yesterday....the guys suspect the noise form the steering rack...left it at holden today for them to have a look....just wondering if anything wrong with the steering rack would it be covered under factory warranty???....i have my car under warranty till july this year...
Ride: VZ SVZ
CAI with POD setup
NEXT:
