Results 1 to 13 of 13
Thread: VZ Central Locking
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Default VZ Central Locking
    I have a slight prob with my drivers door central locking. It seems the button isn't quite coming up higher enuf to unlock door, only a poofteenth in it.
    I have to open the back door & lift up the button.
    Normally it works OK & opens, but now it's playing up. Any Ideas?
    Otherwise I will to get it back to Holden.
    Cheers..
    Knowing these VZ's it's probably another secret safety setting
    in the programming.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by Rovert View Post
    Cheers..
    in the programming.
    there is a small orange clip that holds ur lock button in poistion get a small flat head and un clip the orange tap and move the button up and see if that helps m8, then push the orange tab back in to hold it in the new postion
    Feb 2005
    St Clair
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    does that happen when it rains....my svz did that last yr...went to holden...advsd vz's have this problem...nd 2 leave the car for a day...they'll fix it....i just parked the car in sun for a day...no problems till date...
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
    jet-6's Avatar
    jet-6 is offline Yer im that guy!
    MY06 VZ SX6 ADVENTRA
    Oct 2008
    East Gippsland, VIC
    Its the key lock playing up with the actuator(limiting travel), mine was doing it after rain, then came good a few days later, took it into holden when it was playing up and they swapped the key lock and actuator for new items
    Works perfect now
    05 VZ Commodore Equipe
    May 2007
    VZ SV6
    Jul 2008
    That happened to my right side passenger door the day i got my car, i was so annoyed and everything, but in the process of driving the car around to show all of my mates one of them (who is obsessed with commodores) and said "ah no worries", he just grabbed it and pushed it...dunno exactly what he did but it took him not even 5 seconds and it fixed it.
    I know this doesn't help much, but as far it seems it should be fairly simple to fix
    Feb 2005
    St Clair
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by jet-6 View Post
    Works perfect now
    Holden just rang me they have changed the actuator.
    Thats the same prob im having.
    Car was at Holden yesterday getting a software upgrade (different story), asked the guy about the issue & he said strait away key lock mechanism $290, i said dont worry bout then.
    At least i know what the problem is.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    jet-6's Avatar
    Oct 2008
    East Gippsland, VIC
    If you car is our of warranty dont worry, just take the door card off and put some graphite powder on the lock rods and also some in the barrel and give it a few good cycles, then get some dry-lube stick and put a very thin smear over the outer lock face to make it a little water proof, you wont need much, just a little on the end of your finger to add a thin water proofing layer
    The problem is water gets inside the barrel and lock rod holders and the just get sticky, in time my new ones will play up again, but until my warranty runs out holden is paying
    VZ Thunder SS
    Aug 2008
    After reading this sounds like i just got the same problem!
    Drivers side door lock just doesnt come up far enough and cant open the door... and having a ute means i have to walk all the way round to the other side of the car to open it!
    So in most cases is it the actuator that needs replacing then??
    Was going to attempt to take the door trim off today and see what its doing and attemp to fix it but might just take it to holden while its still under warrenty.
    vz sv6
    Jan 2009
    i've got the same prob, rear door drivers side. but with all these responses i dont need to ask questions lol just going to take it back to holden to fix any ways. under warranty still.
    jet-6's Avatar
    Oct 2008
    East Gippsland, VIC
    Good idea, holdens issue then
  1. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  2. central locking in vn
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 07:47 PM
  3. Central Locking
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 04:26 AM
  4. DIY Central Locking
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 12:34 AM
  5. Vs Ute Central Locking
    By nitro 55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2005, 02:16 AM
