Hey guys,
I picked up the gauges and holder from my mate out of his old mans smashed senator and am having some trouble...
As you can see i have removed the storage compartment from my calais and have placed the gauges in their place.
It appears that i am missing something as it does not clip in place like it did in the senator...
And the problem is that i cant go back to my mates car because its gone!!
Any help would be greatly appreciated.
Im not worried about wiring up the gauges yet, just fitting them first.
Thanks!
VZ Calais
ay m8 the problem is the dash is different, i think it will only fit a normal dash, as my exec has the clips in place for it, did u have the compartment there to put things in before u put the guages there? if so then it will not fit
its the right dash for it, models with climate control dashs are the only ones that can fit it.
it wont fit anything with normal air con, execs sv6's etc
at a guess the senator would of had something that screw to the mounting holes for the flip up storage bin, then the gauges would clip to that
You sure it's related to climate control? I thought it was just dashes with the pop-up compartment won't fit these. I have CC and the pop-top but I'm told gauges won't fit![]()
Mr. eBay seller told me!
VY VZ V6 V8 HSV VDO FULL GAUGE POD & SENDER KIT - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-Feb-09 22:43:25 AEDST)POD WILL NOT SUIT VZ MODELS WITH POP UP STORAGE COMPARTMENT
and
Modified Holden Commodore Gauge Pod Cover 4 VY VZ HSV S - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-Feb-09 21:13:45 AEDST)IT IS suit FOR both VY Climate control Model and Non-Climate Model & VZ NON-CLIMATE CONTROL MODEL BUT NOT VZ CLIMATE CONTROL MODEL
Maybe it is CC related? Do you have CC juzo?
Yeah i do. I talked to my local holden dealer and he said it could be done but only if you don't like money!
Hropic, u have the correct one but ur obviously missing a part that goes underneath, so it sits flush with the dash.
If u didnt, u wouldn't hav been able to fit that part at all.
The Blue One
ok to the op, you need to go to holden and find the mounting piece for the gauges .
to everyone that is struggling to understand what goin on. there are 2 type of dashs, air con and climate control.
the ebay kits are after market ones design to suit the air con dash, as you can see the bit i have circled in red, is an extension of the original gauges
the bit i have circled yellow is from a climate control dash, which makes the area on top of the dash shorter, you can easily tell by how close the gauges are to the end of the mould
if you where to put standard gauages in a air con dash the would be about a 3cm gap, at the front,
also those aftermarket gauges are based on the vy version, the vy dash did not have the bit i have circled to yellow on any model,
Ok guys so ive sorted out a few of the issues.
I have talked to a bloke from holden and he said that yes i am missing a piece that goes underneath the gauges.
In order for them to fit flush with the dash, I need this piece.
He couldnt quote me on the spot but has told me that is it possible to modify the flip compartment that was there originally to act as the missing piece.
Im not too fussed about that for now as i am looking into the cost for getting it all wired up.
Because i dont have the senator wiring that is needed, i was looking into pulling apart the unit and making seperate connections for each gauge.
Sound like a decent idea?
VZ Calais
I had some in my vy berlina which i wired up myself. Took a bit of doing but in the end probably saved a bit by doing it that way.
The Blue One
does your dash top look like this?, there is a few differences in the mounts in the tops of the facias between the models with pop up cover, plate cover etc
edit, just saw your picture again, dosnt appear your facia is compatible with it, id say your up for the compatible facia for it to suit
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
speak to this guy
send him a message i got the full kit from him, he might help u out with the wires ie sell u them separate.
