Results 1 to 23 of 23
Thread: how hard is it to change over from auto to man
    VZ executive
    Feb 2009
    Default how hard is it to change over from auto to man
    i want to change over my gear box, will the new man" computer plug straight into the old plug..
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    im researching it at the moment with the factory holden service manual. at the present, the speed sensor has a different connector, there appears to be a plug that fits over the tcm module connector to keep continuity in the wiring for other modules that use that system,
    at the moment,
    will need to change some wiring
    will need to have computer re-programmed with a tech2 to change transmission
    i need to work out atm how much of the dash wiring accommodates the clutch switch and clutch position switch, i know there is one of the connectors there atm.
    if anyone with a manual transmission could do me a favor, and pop the passenger side footwell cover out and see if there is a plug similar to the one used on the ecm on the front of the motor with a cap fitted to the plug?
    cheers
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ok i found the wiring harness i was looking for, looks to be a pretty straight forward swap, the difference is the manual harness only supports the speed sensor, reverse switch and oxy sensor if a 190kw or my06, it has one plug that plugs to the engine harness at the back of the motor, and another plug that goes through into the dash and plugs in, the auto harness has an extra plug that connects to the tcm module, which will be removed,
    wether all this is plug and play i dont know, but it shouldnt be far off, the only thing that i think may give trouble is the speed sensor wiring, i thing auto is 2 wire and manual is 3 wire
    theres a pic of the harnesses, auto first, manual second
    Attached Thumbnails Attached Thumbnails how hard is it to change over from auto to man-auto.jpg   how hard is it to change over from auto to man-manual.jpg
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    interesting topic but wouldnt the cost of the parts and the labor be well between the 2000-3000?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Archers View Post
    im going to buy and wreck a stat write off
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    i can understand for a wagon because from my understanding they didn't come in any spec with manual, but with a exec sedan probably cheaper to runout and buy a sv6 with the 190kw motor and 6 speed?
    you'd think anyway
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    They def made manual VY Wagons (VY SS).
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by STEALTHY™ View Post
    yep, very very very rare, i know the sedan execs where standard but im not sure the wagons(v6) where given the option in vy's aswell
    vz sedan and wagon was auto only
    STEALTHY™'s Avatar
    Jan 2005
    VT were rare, VX were rarer again.
    Thats the main reason why i looked in this thread, to see how much head**** it was.
    cheers sexy
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    plenty of manual vy ss wagons out there. not heaps but not veyr very very rare, always one on carsales
    no longer a hoon by association - the commodore is gone
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by nicko View Post
    I'd say 400 out of 70,000 is pretty ****in rare
    cheers sexy
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    yer i was just talking bout vz 3.6
    Morticia's Avatar
    Morticia is offline Sneaky Bastard ;)
    VY commodore
    Feb 2009
    Quote Originally Posted by richie_rich View Post
    Can I ask what made you decide to change it over from auto to man?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    Better fuel usage......
    cheers sexy
  16. #16
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by davecunno View Post
    lack of fun ? lol
    **** loads more go
  17. #17
    Morticia's Avatar
    VY commodore
    Feb 2009
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    to make a vy v6 have a chance of chirping second
    SIR LS1
    the two ton go kart
  19. #19
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    for a vy yeah, a vz with a decent aftermarket clutch would do third....
  20. #20
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by andyman View Post
    3rds aren't that big a deal when you can do 4ths every day of the week
    cheers sexy
  21. #21
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ***cough stock v6 compared to modified v8 Cough***
    lol
  22. #22
    STEALTHY™'s Avatar
    Jan 2005
    lol
    Stock V8 actually, just converted to manual
    cheers sexy
  23. #23
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    was worth a try lol
  1. is it hard to change VZ exec speakers
    By palah in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-10-2009, 12:49 AM
  2. How hard to change drivers window?
    By bazzii1388 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 10:33 PM
  3. How hard to change belts on LS1 ?
    By Carlos the bastard in forum LSx Development and Modification
    Last Post: 29-07-2006, 05:56 PM
  4. How hard is it to change dashes on a VK
    By Maccar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 11:22 PM
  5. Auto hard changing second time in drive
    By Spaced in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 12:32 PM
