Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Replacing Oil Pressure Sensor
    VZ
    Feb 2009
    Default Replacing Oil Pressure Sensor
    Hello all,
    We are experiencing the "service vehicle soon" message and it's driving us mad! - from a bit of research, I've found that the oil pressure sensor on the VZ's can cause this message.
    Does anyone have instructions or could give tips on replacing the oil pressure sensor?
    Many thanks in advance.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    VZ
    Feb 2009
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    guys guys guys, remember, service vehicle soon IS NOT A SERVICE REMINDER, this is set when a non emissions related fault is detected,
    to the op, have you properly diagnosed what is cauing the issue, buying a new pressure sensor is expensive and reckless way of fixing a problem, there are oodles of fault codes that can cause the svs message, id be getting it checked with a scan tool before replacing parts,
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ
    Feb 2009
    Quote Originally Posted by andyman View Post
    Thanks for the info guys. Do I have to go to the dealer do have this scan done?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by tepaus View Post
    dealer or any other mechanical workshop with a compatible scan tool
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    HI, I've had the "service vehicle soon" error the last couple of days. Had it checked with a scan tool -free of charge!!!! (not at a dealer, I refuse to go there any more). There were three error codes:
    1) Oil Pressure out of range.
    2) Oil pressure in range. --?????
    3) Lost communications with module.
    I wasn't there, but my wife assures me these are the error codes the mechanic told her.
    The car is booked in to be serviced on Friday so I will post the results when i have them.
    My gutt instinct was faulty oil pressure sender but I don't know about the loss of communications error?
    Wait and see with crossed fingers I guess.
    BTW - Andyman thanks for setting everyone straight about resetting the service notice. Everyone seems to think it is the same as a regular notice, and it just isn't te same! Incidentally it does clear - for a very short period in my case - if you disconnect the battery for a while.
    Ben.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by BerlinaBen View Post
    Ben.
    no worries, its a very silly of showing a fault code, i can imagine alot of people taking there cars to get serviced and an ill informed or workshop without expirance would just change the oil and filter etc
    Jul 2005
    Got it fixed today. It was the oil pressure switch. Cost $132 for the switch plus half an hour labour.
    All good again. No more annoying beeping!!
    Travy's Avatar
    Travy is offline A bogan with style
    Hilux 4x4 Xtra Cab
    Feb 2008
    Had this fault myself over the last couple days, resulting in oil leaking out of it.. Got the switch at trade price, had to buy a special socket to fit it though...
    Took 2 mins to swap over.
    Pain in the ass.. apparently common fault? dumb spot for it imho.
    vz executive
    Sep 2009
    travy mate, where do i get oil sensor socket and can i get trade some how? what was the damage trade?{price}
    vz ss and vs statesman
    Mar 2009
    this mite sound silly but i have the same problem and its the oil sensor but where the hell is it i just cant seem to find it help any one
    VZTHUNDER's Avatar
    VZTHUNDER is offline Enhanced Custom Tuned
    VZ SS Thunder MY06
    Jan 2007
    SA
    gen 3/4 its near the oil filter near the sump (90% sure)
    alloytec its near the oil filter up the top right of the motor (you will need to remove the engine cover to get to it easily tho)
    on both youll need a specail socket to get it off
    Quote Originally Posted by soop View Post
    Since we're talking sh*t here. Petrol. Petrol kills things good. You could even lite it.
  15. #15
    Mar 2009
    found the sensor for future reference it is at the back of the engine on top of it near the firewall behind the manifold in an ls1 and the service vehicle soon message dissappeared after i changed the sensor for any one who was wondering
  16. #16
    VZ Executive Wagon
    Oct 2009
    had same problem twice. Cannot be reset from inside the car. You have to replace the oil pressure sender switch. Apparently there was a faulty batch brought into the country. Holden had the same batch as after market. Had to put up with the warnuing and alarm for 6 weeks !!!
  17. #17
    vz sv6 04 190kw
    Dec 2008
    adelaide
    i all so had the same.. took it to the dealer and said going to cost $320..they said it was the oil pressure switch.. went and brought a scan tool max scan gs500 the other day and when i connect it up and to see the error code.. i see none come up..as in there are no errors with the car.. can anyone help... i havent change the oil pressure switch and it does comes up with svs "service vehicle soon" .. and do you need a special socket to remove it..
  18. #18
    VZ Sv6 & E36 318i
    Sep 2009
    Quote Originally Posted by pirate048 View Post
    yeh you need a tube socket i forgot what size, i did mine couple months ago and just clear the fault code when done.
  19. #19
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    Repco sell the oil pressure switch socket for $18 I think it is. I had the same problem and fixed it myself by replacing the oil pressure switch.
    Oil Pressure Switch - $65 (from Holden)
    Oil Pressure Switch Socket - $18 (Repco)
    The problem was annoying me for a few months... was so glad to finally get it fixed for only $83. Actually I sold the socket to a friend a couple days later for $10, so the repair only really cost me $73.
    As for the price of the oil pressure switch I think I got very lucky. Rang local Holden dealer and this is how the conversation went;
    -ME: Hi, I'm after a price for an oil pressure switch for a VZ
    -HOLDEN: They cost $279 but we are out of stock
    -ME: Wow, really? $279? That seems like a lot!
    -HOLDEN: Ok hold on I'll double check the price
    (put's me on hold)
    -HOLDEN: Ok they're actually $169 but we still don't have any in stock
    -ME: That still seems like too much, I was just on the phone with Ultratune and they quoted $120 to replace the switch, including parts and labour, but there is a 2 week wait on the switches
    -HOLDEN: That sounds too cheap, they must not be using genuine parts
    -ME: Nope, they are definitely using genuine parts... He told me they were waiting on the switches from Holden and is unaware of any aftermarket replacements
    -HOLDEN: Ok let me double check again
    (puts me on hold again)
    -HOLDEN: Well we do actually have them in stock and they are only $65. Sorry for the confusion but that part has been superseded a few times and I had to track it back through the system. I also don't normally work in this department, I'm just filling in for the day
    -ME: Excellent, see you in 15 minutes
    I haven't heard of anyone else getting the switch for any lower than $65... best alternative I found was about $85 off the net somewhere, can't remember the site.
  20. #20
    vz sv6 04 190kw
    Dec 2008
    adelaide
    Question
    Quote Originally Posted by ruzz View Post
    did the fault go away after you change the switch or did you have to clear the fault with scan tool after you change the switch?
  21. #21
    JBDrifter's Avatar
    Oct 2006
    Fault goes away straight away... no need to reset anything. Just replace the switch, it's all you need to do, and it's very very easy.
  22. #22
    vz sv6 04 190kw
    Dec 2008
    adelaide
    so does the scan tool pick up that fault.. or is that a different sort of fault.. the scantool a got is maxscan gs500.. and at this satge iam still learning how to use it and what to look for and what it can do.. thanks for the help
  23. #23
    JBDrifter's Avatar
    Oct 2006
    I don't know the differences between different scan tools, but I do know that some tools can't pick up all the faults. I did a scan using my dad's scan tool (he's a mechanic) and it didn't pick up any faults at all, yes every time I drove the car it gave me the SVS warning.
    Oil pressure switch fixed that though
  24. #24
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    If the Service Vehicle Soon warning appears, and you don't have access to a scan tool, there is a simple way of determining whether the oil pressure sender is at fault.
    Unplug the wiring connection from the sender. If it's full of oil, the chances are good that the sender will be the culprit behind the service message. If the connector is dry, the fault could still be the sender, but leaking oil senders is such a common fault with early Alloytecs that it's worth checking for the oil leak anyway.
    There is a seal within the sender that is designed to keep the sensor mechanism clean and dry. The seal fails pretty early on, the oil gets into the guts of the switch and it faults out. The oil, which is under pressure and very hot, is then able to exit into the connector. There is a seal around the connector so the oil is mostly trapped within the connection and quite a bit will escape when you unplug the wiring. Unfortunately, cleaning out the connection doesn't fix the problem but if oil is present, the switch is stuffed anyway and is very likely to be the cause of your SVS message.
  25. #25
    vz sv6 04 190kw
    Dec 2008
    adelaide
    i unplug the connector from the sender and i have no oil in there.. have read on the forum that a few have had there oil pressure sender show up the SVS fault... and have had to replace it..
  1. replacing the fuel pressure regulator
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2008, 11:07 PM
  2. oil pressure sensor
    By Deathadder in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-08-2008, 08:59 PM
  3. vy oil pressure sensor
    By Deathadder in forum Electrical Wiring / Questions
    Last Post: 09-08-2008, 07:39 PM
  4. replacing fuel pressure regulator
    By johnnny in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2008, 01:29 AM
  5. Oil pressure sensor
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 11:48 PM
