Results 1 to 4 of 4
Thread: coolant bleed nipple?
    VZ Executive
    Mar 2009
    Default coolant bleed nipple?
    Hey, ive always serviced my cars and does anyone know where the bleed valve is on the VZ is for the radiator, i used to own a VX and its not in the same spot. cheers guys
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    remove the top radiator cover, on the driverside top tank there is a plastic screw, unscrew that and stat filling at the engine, once water comes out the hole screw it back in, remember its only plastic, dont do it tight, if you pull the threads youll need a new radiator
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Executive
    Mar 2009
    cheers, i saw that screw and thought it could possibly be the bleed point. Do it tomorrow. So i guess that that is the only bleed points when you drop coolant and refill.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by shane100 View Post
    yes non on the block
  1. How to bleed your coolant system vp
    By centy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2009, 02:41 PM
  2. VZ coolant bleed
    By shane100 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-03-2009, 03:45 PM
  3. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  4. VR 5.0L coolant bleed valve
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 11:22 AM
  5. Brake Bleed Nipple Stripped
    By Demons1964 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-01-2006, 03:14 PM
