Results 1 to 23 of 23
Thread: Vz ss sedan 2006
    vz ss 2006 commodore
    Mar 2009
    Default Vz ss sedan 2006
    Hi guys,im a lady whos desperate for some help!Is there anyone who owns a vz ss 6ltr with an original untouched exhaust system???Im having a major issue with a warranty problem and need to see what an oringinal system should look like as the car yard is trying to shaft me big time.Any help would be much appreciated.Cheers.
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    I Have a 6L Ute and although it is a bit differrent i found this picture that i think shows most of the parts in a sedan's exhaust. (i thing the cats are missing).
    What are they shafting you on?
    Mar 2009
    Hi,thanx for the response.We had the tail pipes changed to have just a little bit of rumble last december,fast forward to about 4 weeks ago and my engine warning light had come on with a check powertrain warning.The car yard had a look and apparently cleaned th 02 sensors,got it back then 2 days later same thing happened.Now saying i need a new cat but wont cover it under warrany coz of slight impact damage(its quite low),turns out its the tinest scratch.We got a 2nd opinion which of course says holden are full of it.Now theyre saying my car shoud have a 3rd cat but its missing???They are claiming further mods have been done,which havent by me.They showed me a system on a 6ltr statesman with the 3rd "cat",but its not the same car so im lost on what to do.They are pulling all kinds of excuses so they dont pay for it,the quote was $1000!
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    There is no 3rd "cat" in a standard 5.7/6L exhaust. You have your headers from the motor going into 2 cats then through two mufflers finally to a single larger muffler right at the rear. Usually finished off with twin tips.
    Mar 2009
    Thats what we've been told by several people.On the statesman they showed us there was a box(if you could call it that)on the rhs about half way down the exhaust,this is what they are telling me i should have but dont.They have ordered a system in to compare to mine,but how the hell do i know if its from a 6ltr vz ss!I realise that the o2 sensors have possibly been affected with the pressure change with the altered tail pipes but is the solution a new cat???
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Do they mean a 3rd muffler? There should be 3 mufflers (as in the pic above), but only two cats.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Mar 2009
    Hi,no they are definatley saying 3rd cat not muffler(we double checked) on that.Saying that though there is no 3rd muffler on my car,hmmm.Now im worried.The cats and piping are original holden parts we got told by the second opinion we got from the performance centre my brother deals with and they were the ones who changed the tail pipes to start with.
    VZ SS UTE 6L M6
    Mar 2009
    ive got a VZ ss 6L, and yes it looks like a 3rd cat.
    i can see where the 2 cats are up the front then there is one that is on the drivers side back a bit that looks like a more traditional cat(older).
    hope this helps
    Mar 2009
    Hi,thanks for your reply.My 6ltr doesnt have that at all.What your explaining is what the car yard pointed out,crap crap crap!!!So does anyone know if the solution to my problem is def at new cat?
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Im interested in the fact they ordered one in to try and prove the point???
    Holden usually are full of you-know-what.
    As for the problem its hard to tell but I would be interested in finding out whether its a faulty O2 sensor or not first as the 02 and cat go hand in hand. I could be wrong but just because they cleaned it up then it came good for 2 weeks doesnt nessicarily mean the sensors not to blame either.
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Quote Originally Posted by Torquative View Post
    One would think that if the sensor came good for two weeks after being cleaned and then started causing trouble again, the sensor is the problem. I would suspect that it was not the cleaning that solved the problem for two weeks, rather the fact the sensor was disturbed and has started working properly as a result albeit for two weeks. I would suggest they replace the sensor then work from there.
    Holden generally aren't the problem it's just inept dealers
    My Garage:
    VZ SS 6ltr 6 speed silver
    VN 5ltr 5 speed Gold (Ex NSWPF Highway Patrol)
    VH EFI 5ltr Supra 5 speed tiger mica
    XC Barina SRI 1.8ltr 5 speed silver
    Sep 2005
    Newcastle
    I just had a squizz under my VZSS and it too has the extra cat thing. It is only on the pipe running from the right bank so I doubt it actually is a cat. I checked in my VY workshop manual, they don't have it.
    My Garage:
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    so this is a 6lt motor just to make sure?
    this is the factory exhaust, so yes it is meant to have the third resonator < its a resinator not cat
    Attached Thumbnails Attached Thumbnails Vz ss sedan 2006-exhaust.jpg   Vz ss sedan 2006-key.jpg
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  15. #15
    danja's Avatar
    Jan 2006
    They must be talking about item 5, I don't recall seeing that on my LS1 VZ.
  16. #16
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
  17. #17
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Don't be suprised if the mechanic at Holden is just a 2nd day apprentice and thinks a muffler IS a cat converter mate......
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
  18. #18
    Mar 2009
    Wink
    So holden has rang saying they have the exhaust in to compare with mine,it has the 3rd cat,resinator or whatever freakn else its called.So long story short they"re not covering it under warranty(i know shocker)!!!They did "clean" the 02 sensor the first time,it only took 2 DAYS for the engine warning light to come back on not 2 weeks!I think we're are going to get new headers,high flow cats and the rest of the exhaust done to join up with the tail pipes and hopefully that fixes the light problem aswell as me getting a sweet running/sounding 6ltr!Thanx to everyone who has responded,you guys are a great resource
  19. #19
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by natsvz View Post
    only way to go for an 8, standard pipes are uber ghey, they dont justify a v8's presence like it should
  20. #20
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
  21. #21
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by BANKS View Post
    why does it have a reso on one side? :S
    might be to do with resonance, hence there is also a second brace on it
  22. #22
    VZ SS UTE 6L M6
    Mar 2009
    all i know is mine is quieter then my GF's VY v6, and this is with the rear pipe section removed at the diff.
    as soon as i can afford it im getting my exhaust system done.
    also apparently, you cant use certain types of silicone as they ruin the o2 sensors.
    but i dont think you have changed anything before the 02 sensors.
  23. #23
    Mar 2009
    Nope only changed the tailpipes so far.
LinkBacks (?)
  1. 14-03-2009, 08:24 PM
  1. Help me mod my 2006 VZ Ute
    By Thats-How-We-Roll in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2009, 08:47 AM
  2. 2006 VZ Ute
    By Thats-How-We-Roll in forum VY - VZ - WK - WL - V2
    Last Post: 29-01-2009, 09:43 AM
  3. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  4. 2006 - Can HRT do It??
    By holden#1 in forum Motorsport
    Last Post: 20-05-2006, 09:16 PM
  5. New 2006 VZ SS 6.0Lt or VE SS - which would you buy?
    By chosen_one in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-02-2006, 04:26 PM
