Results 1 to 17 of 17
Thread: calais rear bar insert
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    Default calais rear bar insert
    hey guys, in my quest to blacken my car to hell i want to put some calais tail lights in it.
    the problem being its an exec so by removing the stock lights i will be removing the rear facing reflectors, thus making it illegal.
    so i was thinking, maybe i could stick two reflectors onto the bumper but that would look fairly shite. then i thought, maybe i could affix the calais bumper insert onto my bumper ftw!
    so my question: does anyone know if this is an order-able part or is it just the calais bumper ill need? also, would anyone happen to know how its fitted to the bumper (clips, tape, glue etc)?
    cheahs.
    fyi:
    Division 15 Rear reflectors
    118 Rear reflectors
    (1) A motor vehicle with 4 or more wheels, and a trailer, must have a rear-facing red reflector towards each side of its rear.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    To fit the Calais lights, you have to either fit a Calais/Berlina bar, or alter your existing one to enable the lights to fit. They won't fit with the Exec bar in its standard form.
    Then, if you fitted the Calais bar, you could add the insert. It's made up of three separate parts, (centre black strip and two reflectors.) Reflectors are about $30 each and the strip was about $70.
    You could fit them to the exec bar but it would look crappy. The Exec has that black centre panel low on the rear bar and the Calais has a narrow recess in the bar to accommodate the strip. When the strip is fitted, it's pretty well flush with the bar.
    To fit it to the Exec bar, you would have to run it higher up the bar in the painted section, above the black insert.
    Wouldn't bother unless you do the job properly and change all the rear parts.
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    haha every time i hear about calais lights in exec rear end the story changes.
    ebay - calais fit in exec
    ls1 - calais fit in exec
    holmart - calais dont fit in exec
    here - calais dont fit in exec
    ss/sv6 - dont fit in exec
    thanks for the input though
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    I can tell you, what you have just been told in the second post is spot on!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    i'm talking about vz calais lights in a vz exec just to clarify
    ebay store:
    TAIL LAMPS VZ CALAIS SUITS ALS BERLINA GENUINE NEW-PAIR - eBay Tail Lights, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 16-Mar-09 00:04:09 AEDST)
    GENUINE HOLDEN VZ CALAIS SEDAN DARK TINTED TAIL LAMPS
    SUITS:
    VY CALAIS & BERLINA
    VZ EXECUTIVE ACCLAIM CALAIS BERLINA COMMODORE - BRAND NEW
    so this would hold true if Calaber is referring to VYs
    not wanting to sound argumentative at all, i guess ill just get whoever i buy them from to give me a guarantee theyll fit and if they dont ill just return them or get a calais bumper
    Supercharged VU SS
    Feb 2006
    The Shire
    i can tell you by parking my old sv6 side by side with my brother berlina, there is a big difference in size, deffently wont fit
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    what wont fit?
    from what ive heard:
    interchangable: calais, berlina, executive
    interchangable: ss, sv6
    VZ Calais, VS Exec, VL Exec
    Mar 2005
    Mandurah W.A.
    calais tail lights dont fit in a exec, i know vy/vz calais lights are interchangeable
    i guess as naf33n said the berlina would be the same deal as the calais and will fit
    with the exec i believe the ss/sv6 lights will fit as there the same size from wat ive seen, but dont quote me on it though
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by dmar View Post
    what wont fit?
    Hi Dmar
    My avatar isn't the best, but it is a VY2 Berlina fitted with VZ Calais rear lights and bumper insert and the lower rear quarter extensions.
    The VY came with two basic rear bumper facias on the sedans, and two basic sets of tail-lights, with slight variations according to trim level.
    Executives, S, Acclaims had one bar, with the large black insert in the lower centre of the bar. The S insert was slightly different to the other two.
    Berlinas and Calais had the other style of bar, with the recess running across the lower part of the bar. This recess was treated differently for Berlina and Calais depending on whether they were Series 1 or Series 2.
    Series 1 Berlina had no insert in the recess (although many were fitted with them.)
    Series 1 Calais had a single plain black strip fitted.
    For Series 2, the Series 1 Calais strip was fitted to the Berlina, and the Calais had its own new strip, made up of two reflectors and a mesh pattern centre black strip.
    On the basic bar, the tail-lights were shorter (that is, the bottom of the light sat higher up the car by about 20 mm or so, and the bumper was moulded with extra height in that area to meet the smaller tail-light.
    The Berlina and Calais had a deeper light assembly and the bumper was slightly shorter in that area. Series 1 had the same lights for both Berlina and Calais, Series 2 Berlinas were unchanged but the Calais had its own design.
    As far as interchangability goes, you cannot swap Berlina/Calais lights into the base model without either cutting back the basic bar, or fitting the Berlina /Calais bar.
    You can fit the Exec style lights to a Berlina/Calais, but will be left with the 20 mm gap between the bottom of the light and the bumper (and who would do this anyway?)
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    In the vz's the calais/berlina lights will fit in an exec. You guys are thinking of the vy's. My mother has a vz exec. and they are the same size as the calais/berlina lights.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by juzo View Post
    Dead right. My bad. I was thinking we were talking about VY's.
    The VZ facelift was nice and cheap for the General, just use VY Berlina and Calais bits for the Execs.
    To the OP - cancel all I said earlier. Calais lights will fit straight in where your existing Exec lights are, but you will need to add the reflectors and insert into the recess in the bumper to keep your car legal. The Calais lights don't have in-built reflectors.
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    hahah oh boy
    thanks calaber/everyone
    sucks about the reflectors though
    adding a rear bar turns a nice $400 upgrade into a ~$900 upgrade
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    hahah oh boy
    Dmar
    If you have the correct VZ rear bar, the recess for the insert should already be there, in which case the inserts are only about $100 complete with reflectors. The VZ base models just used the VY Berlina rear bar without some of the trim like the reflectors.
    My apologies for the earlier confusion. I should have realised I was on the VZ forum, not the VY. "Duhh!"
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Quote Originally Posted by Calaber View Post
    Dmar
    Just to hijack the thread...
    So if i'm correct with what your saying, I should be able to fit the inserts into my bar since it already has the recess? (VZ exec bar). Do they just clip in or glue in? And a question to all does anyone know what the part numbers are for the inserts and the reflectors.
    Cheers guys.
  15. #15
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by vp_berlina View Post
    Cheers guys.
    If you have the proper VZ exec rear bar, it is the same part as a VY Berlina and the insert will fit in after you drill a number of holes for the clips that retain it. I have attached a couple of photos of a standard Berlina insert I still have sitting around to show what the back of the insert looks like - the VZ one is different at each end and has less clips holding it on. You could probably cut them off and stick the insert on if you wanted to.
    The reflectors are retained by two screws each. You will need to drill the holes for them.
    You could probably cut them all off and stick the insert on if you wanted to.
    The VZ part numbers are:
    Reflectors: 92174544 and 92174545 List price $27.50 each
    Insert: 92174549 List price $23.10 (cheaper than I thought)
    Sorry forgot the photos - check next post.
  16. #16
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
  17. #17
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    Cheers for that, Calaber
  1. Changing Rear Bumper Insert To SS/SV6
    By vykeith in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-02-2009, 01:02 PM
  2. WTB:VS calais II front bar insert
    By shanhsv in forum Swap / Wanted to Buy / Trade
    Last Post: 28-08-2008, 01:49 PM
  3. VS calais series 2 front bumper insert?
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2008, 06:31 PM
  4. Vp Tail Lights & Rear Centre Insert
    By Trentasaurus in forum News/Updates
    Last Post: 03-03-2004, 05:20 PM
