Hi all,
I have a VZ executive that has only the front power windows,
does anyone know if there already is the complete wiring loom in the car so I can add rear electric windows with out having to change or add any wiring? Like is it hidden in the pillars or anywhere else?
Cheers.
according to my documents, the bcm in a executive should be able to run rear power windows, and wiring for the windows should be installed as far as the pillars where the wiring pokes through into the door
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Thanks andyman, positive rep for you![]()
cheers, thanks for that
Do you have an idea of how much it would cost for rear electric door trims??
thanks
where is the power windows switch actually located in concern with the rear door trim?
