Results 1 to 4 of 4
Thread: Where did my brakes go?
    2005 VZ Exec - 95 VS Executive
    Jan 2007
    Default Where did my brakes go?
    Ok so i had this funny thing happen a few weeks ago, i thought it may have just been a random thing, but reading another thread i noticed someone mentioned a wierd glitch with brakes, soheres my story.
    i was doing 60kmh comming up to a round about and started slowly braking, car wasnt pulling up as quick as normal so i pressed a bit harder on the pedal, still wasnt slowing as quick as it should, round about was just infront of me and was still doing 50kmh so i pushed my foot all the way, the brakes went to about an inch from the floor and then pop the pedal went all the way to the floor and there was a grinding noise on the front right of the car, car pulled up just in time but i had no brakes the pedal was loose.
    got through the round about pulled over checked everything, brake fluid, leakes, pads, calipers etc. turned car off and back on a again, pumped brakes all good, everything was working again.
    all i can think of is i had air in the brakes somewhere and its blown it out and i lost my brakes, doesnt explain the noise though.
    anyone else had a similar problem?
    '05 VZ SV6 A5
    Mar 2008
    Auckland, NZ
    The noise is the abs doing its thing. Have had it happen to me as well. ABS seems to go a bit awol when you hit a slight bump under braking.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The Noise is the ABS working, as for the pedal going to the floor i cant explain that.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The peddle should never be able to go all the way to the floor as a "once off"
    You cant blow out air and still have brakes while driving. I'd be a bit worried about this issue......
    and 3 Dangerous non ABS VN's
LinkBacks (?)
  1. 22-03-2009, 06:17 PM
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. PBR Brakes on S-Pac
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2006, 02:35 PM
  3. brakes
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2006, 10:00 PM
  4. vk/vl brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2006, 04:55 PM
  5. Brakes
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:45 PM
