Results 1 to 8 of 8
Thread: power steering,driver belt?,auto shifter,calais strip
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Talking power steering,driver belt?,auto shifter,calais strip
    my questions are for a 2006 model vz v6 exec.
    hey guys i just got this
    Handbrake cover VY VZ - eBay Accessories, Interior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 19-Mar-09 20:13:37 AEDST)
    and was wondering if i need to take the leather cover off the bottom of the shifter [the black material]? if so i will get a new one as mine is average.
    also is there a how to, on flushing Ur power steering fluid out?
    also i need to replace my driver belt? is that right? does anyone know how to do this? while I'm doing this belt should i do anything else?
    also the chrome strip on the Calais thats on the bonnet above the grill, how does that go on?
    all help appreciated thanks Scott
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    the chrome strip comes in three pieces from holden, the mounting bracket, chrome strips, and mounting nut plugs and screws, if your car has the plastic clips for the bonnet protector, you remove them and fit the nuts inside the holes, assemble the chrome strip and bracket off the car, you will notice on the chrome strip there is a piece of the cast that sticks out where the sort of seal runs along, snap that off so it dosnt damage the paint, then bolt it up to the car
    not sure what your on about with the drive belt?
    not sure on the shifter and brake, i think they just clip together, and possible a screw at the back of the gear stick?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by andyman View Post
    holden told me my driver belt needs replacing at a cost of $125, i figured its the belt that goes around the pullys?? im not sure either thats why i asked,
    thanxs for the help with the chrome strip m8
    i have changed the shifter to the chrome insert im just not sure about changing the grip m8
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Archers View Post
    ill have a look around at the h/brake later,
    does the seat belt not retract, or has it frayed or got damages anywhere on it?
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    this is it m8 is it simple to put on?
    http://cgi.ebay.com.au/VE-VZ-V6-Comm...1%7C240%3A1318,
    thanxs for the input
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ah ACCESSORY drive belt lol, now im with ya,
    easy as sin, gab a piece of paper, draw the pulleys, and draw the belt around it, grab your 1/2 breaker bar, insert it into the tensioner arm and move the tensioner around enough to slip the belt off, then install the new belt around the pulleys in the right order, to make it easier, run the belt in the tensioner, and use one of the smooth pulleys like the near by idler to slip the belt on,
    the job is made alot easier if you remove the radiator cover and the intake pipe
    thats if the belt does need to get swapped, holden may be pulling your leg
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    it slips at 3500 revs so i think it is right, they said 125 fitted and if i get it for 30 well thats even better.
    i got boot for the shifter in red so i will see how it goes on lol thanxs for the help m8
  1. V8 Power Steering Belt Flying Off
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2011, 05:21 PM
  2. Tightening V8 Power Steering Belt
    By Demons1964 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2010, 08:38 PM
  3. Calais Power Steering Troubles?!?!
    By Troyziee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2009, 11:11 AM
  4. How do you adjust your power steering belt in the 5L
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2008, 08:49 PM
  5. VY II Driver Seat Belt Reminder Alarm
    By neon_crossing in forum Electrical Wiring / Questions
    Last Post: 22-02-2007, 12:36 AM
