Results 1 to 11 of 11
Thread: Lock Chirp - Disobedient Options Menu
    VZ Executive
    Mar 2009
    Default Lock Chirp - Disobedient Options Menu
    Hi
    I've got a 2005 VZ Executive wagon and for some strange reason it's decided to give a horn chirp (3 chirps) every time I lock it even though it has never been set to use both indicators and horn. I check the Options menu and there it is in front of me - 'Indicators' as the lock indication.
    I try to reset it back to Indicators - still chirps, I try to set it to Indicators and Horn - chirps, and then reset it to Indicators - still chirps!!!!
    I'm getting to the point of imitating Basil Fawlty and giving it a sound thrashing with a tree branch, and seeing if it will try chirping after that ;P.
    Has anybody come across anything like this?
    GrumpyOldMan
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    this is telling you you have an issue with the locking system, lock the car as you normally would, then check all door are locking including the tailgate, if you deadlock it, while you are in the car, make sure all door lock cant be opened, if it does the actuator has an issue on that door, also check the door sensors are working are working
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Executive
    Mar 2009
    Hi Troy711
    Quote Originally Posted by Troy711 View Post
    Have you tried the 'Restore To Factory Settings' option?
    Thanks for the reply, did try turning it back to factory settings but this didn't have any effect :0).
    GrumpyOldMan
    VZ Executive
    Mar 2009
    Hi andyman
    Quote Originally Posted by andyman View Post
    You are onto to something here, after locking (the deadlocking also sets off the horn chirp), the rear passenger door still opens and the alarm sounds and the message comes up that the rear passenger door was opened. Does this sound like the actuator, and does it have to be replaced?
    GrumpyOldMan
    EQUIPED is offline AM VZ
    VZ Equipe 2005
    Sep 2007
    This has happened to me on a couple of occassions. I took it to the dealer and got it fixed under warranty. However, the problem is certainly in one of the door locks.
    Lock the car --> Look at all the door locks, and you will notice one of them isn't quite completely down --> Unlock all doors --> Open that door with the latch only half way down --> push it in completely --> close the door --> relock the car and see if the alarm sounds again.
    LATEST NEWS: The difference between a pigeon and a London investment banker - The pigeon can still make a deposit on a BMW
    VZ Executive
    Mar 2009
    Hi EQUIPED
    Quote Originally Posted by EQUIPED View Post
    Thanks for the reply.
    I tried this and the chirp didn't sound, but now the door won't unlock . Looks like the door lock has gone and a (hopefully inexpensive) visit to a mechanic is on the cards.
    GrumpyOldMan
    VZ Exec Sedan Alloytec
    Feb 2009
    Scarborough WA
    Have you checked the child locks on the rear doors also. I don't know if they could be a contributing factor. Just an idea.
    The only time I get the horn making any sounds when I lock mine is if the front passenger door is open or if I deliberately press the courtesy light button on the drivers door side and try to lock it. But that horn sound is a rapid machine gun style - I guess signifying something is wrong rather than the normal beep, beep of the locking/unlocking sound.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Yeah the horn means there is a problem with locking. Is the lock getting stuck going up or down or just not working at all? If it's getting stuck, lube it up, if it's dead you can probably get one off a VT/VX/VY/VZ at the wreckers for a couple of dollars.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VZ Equipe 2005
    Sep 2007
    Quote Originally Posted by GrumpyOldMan View Post
    Hi EQUIPED
    GrumpyOldMan
    It seems that the latch is getting stuck somewhere. Did you try lightly pushing it out (of course, from the inside)?
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    open the driver door, turn ignition to "on" and turn back off, check all doors are firmly closed, and try locking the car again. you usually find that chirping is warning you of a door thats not correctly closed. if that fails check bonnet and boot are properly closed too.
  1. No chirp with remote lock.. what's dead lock?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 04:06 AM
  2. Options Menu?
    By boofis in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-12-2008, 03:29 PM
  3. Who cant get their car to chirp? Why not?
    By pedrotski in forum V8 Development and Modification
    Last Post: 25-11-2008, 04:22 AM
  4. i want it to chirp
    By VPS2 in forum General
    Last Post: 24-11-2008, 07:09 AM
  5. Brakes chirp...
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2008, 05:35 PM
