Results 1 to 5 of 5
Thread: VZ noise
    sxcmonkey is offline SxcmonkeY
    VZ v6 commy
    Mar 2009
    NSW
    Default VZ noise
    hi fellas
    recentely i have relised that my car started making noise
    it is like metal shaking or vibrating or tingling sort of sound
    first it sounded like CAT,,, so i bent down and started hitting exhaust but couldnt hear nothing
    then i started testing
    it makes sound when im driving and put my foot down
    even little tap it made noise
    and i stoped at carpark where it was quite and echos alot
    handbrake up foot on brake and in drive i stated tapping and it made shaddering or tingling or metal vibrating sound
    im bit worried about tranny as well
    it kinda engages gears roughly
    when it engages into 2nd,3rd it makes a clunk sort of sound and it vibrate or shakes a bit....
    anyone had similar problem or knows of what it could be?
    i will be putting my car up on hoist or jack it up and have proper look at it soon but wanted to find out if anyone knows of or had similar sound or problem..
    thanks guys.
    VZ SV6, VR Executive, VL Calias
    Sep 2008
    Wollongong
    Not sure i can help you however my SV6 has had 3 gear boxes replaced under warranty and i still have the noise you mention, do me a favour travel on a quite road doing about 60km and hit the brakes hard, let me know if you get the noise, if so do it again and accelerate after the noise and see if the car doesn't want to go anywhere or realy slugish.
    Let me know.
    P.S Check the harmonic balancer to see if its loose.
    VZ v6 commy
    Mar 2009
    NSW
    finally i found out it what was caused noise
    it was the heat sheild on the exhaust
    after the cat...........
    lol
    VZ SV6
    Feb 2008
    Bayside Melbourne
    Hey Monkey,
    My SV6 is doing the exact same thing - where about's along the exhaust did you need to tighten it up? I.e can I do it from the engine bay or do I need to get under the car and where abouts.
    Thanks heaps
    Andrew
    VZ v6 commy
    Mar 2009
    NSW
    hey there andrew
    it cant be done from the engine bay
    its better off putting up on hoist
    could possibly do it with jacking the car up
    its the one straight after the extracters or after cat
    i havent got a chance to actually get it up and tight it up or have a good look
    but try kicking the tail pipe and you will hear where about the noise is coming from
  1. Noise
    By R0d in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 11:18 PM
  2. Rca Noise?
    By jaisvz in forum Car Audio
    Last Post: 23-08-2006, 11:06 PM
  3. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
  4. Noise in car
    By rgfoster67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2005, 05:33 PM
  5. Gen III V8 Noise.
    By Jaime S. in forum General
    Last Post: 10-01-2004, 01:24 AM
