VZ alloytec (how do i change spark plugs)
swift85
VZ EXECUTIVE 3.6 WAGON
I am wanting to change plugs on my VZ alloytec,my question is how do i get to them and how do i replace them.is it a hard job?
ashbox
back in black
The Car
something black
its a manifold off job
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
As mentioned u have to take off the Manifold,
There are 5 bolts ontop, undo them, then disconnect all hoses it will take abit of effort to get off.
When u take it off put a rag covering each of the 6 intake holes to stop dirt entering. All you have to do now is disconnect each of the coil packs to access the plugs.
Benboy
Hill River, SA
2007 SVZ Wagon
Might pay to obtain (buy) a replacement gasket for the 'manifold cover' in case you damage to old one before you do the job.
swift85
Are the manifold bolts need to be done up with a tension wrench.
And is the job able to be done by someone with a bit of mech knowledge or do you need to be a qualified mechanic.
How do you get the plugs out (do you unclip the electrical harness and undo the one bolt to free the terminal from the plug?)
danny1987
vs commodore sedan
when do u chage them on the sv6 my book says 2 different times one page says 90 one says 120 which one is it???
IPCOlsenVZ
05 VZ Commodore Equipe
What are you referring to? tension?
Tension: 16-20Nm for the plugs.
swift85
Tension the bolts for manifold
