Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree4Likes
Thread: VZ alloytec (how do i change spark plugs)
    VZ EXECUTIVE 3.6 WAGON
    Mar 2009
    Default VZ alloytec (how do i change spark plugs)
    I am wanting to change plugs on my VZ alloytec,my question is how do i get to them and how do i replace them.is it a hard job?
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    As mentioned u have to take off the Manifold,
    There are 5 bolts ontop, undo them, then disconnect all hoses it will take abit of effort to get off.
    When u take it off put a rag covering each of the 6 intake holes to stop dirt entering. All you have to do now is disconnect each of the coil packs to access the plugs.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Might pay to obtain (buy) a replacement gasket for the 'manifold cover' in case you damage to old one before you do the job.
    Mar 2009
    Are the manifold bolts need to be done up with a tension wrench.
    And is the job able to be done by someone with a bit of mech knowledge or do you need to be a qualified mechanic.
    How do you get the plugs out (do you unclip the electrical harness and undo the one bolt to free the terminal from the plug?)
    vs commodore sedan
    Jul 2005
    when do u chage them on the sv6 my book says 2 different times one page says 90 one says 120 which one is it???
    05 VZ Commodore Equipe
    May 2007
    Quote Originally Posted by danny1987 View Post
    What are you referring to? tension?
    Tension: 16-20Nm for the plugs.
    Mar 2009
    May 2007
    vs commodore sedan
    Jul 2005
    May 2007
    Shit I totally miss read your post and went off at a tangent. I had a look through my owners manual (which covers the stock and the 190 model) and I could only find 120km interval. Flip a coin I guess.
    VZCalZone's Avatar
    VZCalZone is offline now choppin the VZ
    vz calais, vx2 exec
    Sep 2005
    I'm lifting the manifold but don't want to do damage. I've taken out 5 bolts and disconnected 3 hoses, one at the intake and 1 on each side halfway along. I've got the front loose but something seems to be holding it at the back. Lifting harder is probably the way to go but wanted to check. Its a 190 not that it should matter. any quick advice would be appreciated
    ps how the hell do you get the plugs out after undoing them, they're a mile deep
    That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced.
    Scientific American, June 2, 1909.
    Drinking and driving: there are stupider things, but it's a very short list.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    there is a bolt at the very end of the manifold only a short one, look over the back near the map sensor and you should see it, its next to it, have you also disconnected the lead to the variable intake actuator?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Holden
    Nov 2010
    I know this post is very old, but your doing it all wrong. To save time, and the paper gasket in between the 2 halves of the manifold, you leave in the passenger side front bolt, and the drivers side rear bolt(very back of motor). These 2 bolts don't go all the way through, they are only into the bottom half of te manifold. This means u can then just chock up the front of the manifold with a block and then proceed the plug change. You should never have to replace the gaskets when doing plugs on a vz. Ve's are a different story tho, as there is less room.
  15. #15
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by mitch_893 View Post
    care to elaborate on this?
    if your lifting the manifold chances are the paper gaskets will break therefore, you've gotta replace them
    Chev badges are an instant fail
  16. #16
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    sounds too much like hard work. think ill drop mine into the mechanics and go fishing.
    i do as the voices tell me
  17. #17
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    If you wanna pay me, I'll come and do them :P Only a Stones throw away from Kanwal
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  18. #18
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by ashbox View Post
    The manifold is a 2 piece item, if you do not undo the front right and rear left bolts the manifold does not seperate therefore the paper gasket doesnt get damaged.
    Silver Certified.
  19. #19
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by RiCeY View Post
    the inlet manifold is a once peice....
    and if you dont undo all the bolts...how are you suppose to lift it? you'd still not get any movement
  20. #20
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Yes youd know more than someone that works on these engines every day, idiot.
    Silver Certified.
  21. #21
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    never said i did, but i've pulled the inlet manifold off my old vz and that was my experience so, i'd appreciate the idiot comment being removed...
    cheers
  22. #22
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The inlet manifold is a 2 piece, seperated by a paper gasket.
    Not removing the bolts I mentioned allows the whole manifold to be removed without seperation. Those 2 bolts only hold the two parts together, not hold the manifold to the block.
    Silver Certified.
  23. #23
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    cheers
    No. You made a dumb comment based on doing something wrong. Idiot suits.
  24. #24
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    how is following a set of instructions, doing something wrong...?
  25. #25
    Nov 2008
    Smithton, Tasmania.
    Because the instructions were wrong. Holden tech just said so.
LinkBacks (?)
  1. 12-11-2011, 07:20 PM
  2. 29-10-2011, 08:55 PM
  3. 22-10-2011, 11:25 AM
  4. 26-08-2011, 06:00 PM
  5. 18-08-2011, 12:11 PM
  6. 14-06-2011, 12:14 PM
  7. 25-05-2011, 02:47 AM
  8. 13-05-2011, 12:58 AM
  9. 30-04-2011, 12:01 AM
  10. 28-04-2011, 07:19 PM
  11. 20-04-2011, 09:41 PM
  12. 13-06-2009, 08:16 PM
  1. vz 2006 crewman ,change spark plugs at 80 000 ?
    By RED HOT RUBY in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 12:08 PM
  2. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  3. spark plugs - how to change?
    By VTS07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2007, 02:48 PM
  4. change spark plugs now haveing lots of trouble
    By scagsdale in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2006, 09:39 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
